Hello.
Yesterday i updated from RC1, to the current release and my nfs mounts went crazy. Before the update i only had to mount the root of the pool, and all the sub-datasets were automounted on demand.
But after the update only the pool root is visible, cant access any datasets.
I have managed to fix the problem with manually addig the "crossmnt" option to the /etc/exports file, but i'm certain this is not the intended way, (and not permament).
Is this an intended change from RC to RELEASE, or i managed to mess something up? What can i do to make this "fix" permanent?
