Truenas core jail - startup python script exploding after 3 minutes
Thomas_VDB
Hi all,
As the title says, I have created a small python script that reads a TCP socket, corrects the data and sends it back.
When I run the script in my jail via this command, it continues to run beautifully (until of course I close the session) :
/usr/local/bin/python3.9 /root/mbgateway.py
Now I have made a rc.d startup script to run in after the boot of the jail :
After creating the startup script, I did'nt forget to :
chmod +x
and then enable the service
#!/bin/sh
# PROVIDE: mbgateway
# REQUIRE: LOGIN
# KEYWORD: shutdown
. /etc/rc.subr
name="mbgateway"
rcvar="mbgateway_enable"
load_rc_config $name
start_cmd="${name}_start"
stop_cmd="${name}_stop"
mbgateway_start() {
    echo "Starting mbgateway"
    /usr/local/bin/python3.9 /root/mbgateway.py &
mbgateway_stop() {
    echo "Stopping mbgateway"
    # You might want to add logic here to stop the script gracefully
run_rc_command "$1"
Now when I run the jail, I can see (on the other end of the socket-comm) the python script is executing perfectly.
But after 3 minutes it stops.
What could be the issue?
It doesn't stop when I run the python script manually. (but then it only runs as long as the terminal session exists).
anodos
Sambassador
Hi all,
chmod +x
#!/bin/sh
# REQUIRE: LOGIN
# KEYWORD: shutdown
. /etc/rc.subr
name="mbgateway"
mbgateway_start() {
mbgateway_stop() {
run_rc_command "$1"
From standpoint of managing a python script via rc system, you can use `daemon(8)` to manage the application, write a pidfile, and lower privileges. See man daemon.
Patrick M. Hausen
Put these in your script right below the initial comment section:
set -x
exec >/tmp/startup.log 2>&1
Then look for hints in /tmp/startup.log. Also consider using the "daemon" utility instead of just an ampersand to background the process. Could be something with your script wanting to output something but not having a controlling tty for example.
Thomas_VDB
set -x
Just putting these 1 lines of code in my script, apparently helped.
The python script doesn't stop executing anymore (been waiting 10 minutes now).
Can this be explained?
Thomas_VDB
Too soon. It stopped again.
Can't find anything usefull in the log. The log just stops between 2 TCP packets.
Patrick M. Hausen
Is there a "global debug flag" for python? So it will print why it is terminating? That should end up in the log, then.
