TrueNAS CORE 13 slower then 12 perhaps, raw disk copy seems slow, general performance seems OK
damjank
I have TrueNAS Core version 13, no beta, went from 12 to 13 directly.
Anyway, I have pool-a and pool-b, pool/b is composed from 4 x 6TB HGST Ultrastar 7K6000 disks (HUS726060ALE610) for data and 1 x Huawei ES3600S V5 800GB SAS for cache. Now, I have 2 zvols shared over 10GB iSCSI working fine, no issues sofar. The VMs are responsive and thats it.
I recently purchased 4 new 14TB Toshibas and I am transferring some files from older pool-a that is made up from 3 x 4TB HGST Deskstar HDN726040ALE614. No biggie, just some old documents, nothing directly running, archive only.
I logged on to SSH session, added screen, and inside I run cp -a /mnt/pool-a/docu/* .
This is now copying but as far as I look, this is doing at about 35-50MB/s, in 40min it coped about 134GB. There is a long way to go towards about 3TB.
Now to what should I account this?are the drives pwned (no SMART errors) or I made mistake with drives themselves (no drive has ever been offline, marked as bad or whatever in the last 14 months) or there is speed difference from TNS12, initially I coped to this rig with about 135MB/s.
Any pointer or hints would be greatly appreciated. I know, that eventually it will copy but - it would be nice to know if I made complete crap from it and I can fix it or there is something else going on...
PS: the rig is a Supermicro board having Intel(R) Xeon(R) CPU E3-1220 v6 @ 3.00GHz and 48GB of ECC RAM.
Thx in advance!
rgD
You're measuring in throughput, but you're potentially copying a large number of smaller files, so you should consider file count as a better measure of this job (and thinking about IOPS).
Also with an IOPS-heavy job like that, your pool is likely suffering from a lack of IOPS to handle it any faster.
Matadata-only L2ARC or a metadata special VDEV may be worth consideration of it's an objective to be able to copy large numbers of small files quickly.
damjank
Hm, did not think of that. Seems that ent ssd is ont even making that much of a big deal. Perhaps to invest into another to add meta vded for cache. All i know is that curently it is at stage that there are much 3-4gb files…
What even more disturbing, vms making many small writes are gling to be battling for io and/or writes….
