I should probably make two posts, but what the heck. Here's my issue. I'm running truecommand in a docker container via the following docker-compose file entry:
I also have a nginx reverse proxy in front of truecommand (currently only http). Here's my nginx.conf virtual domain file:
So my problems:
Taking the reverse proxy out of the process:
1. I can access the login screen. I can authenticate. My freenas installation is shown.
I click on the freenas server, and I get this:
Unfortunately the only thing I get in the docker logs is this:
UI Socket Closing: QDateTime(2020-10-23 02:51:50.039 CDT Qt::TimeSpec(LocalTime)) "4" "127.0.0.1"
Is there a way to increase the log level on the docker image to see why this is failing??? I've used this docker image before and can only tell you I wasn't getting this problem like a week ago. Crashing only occurs with Chrome Version 86.0.4240.111 and Firefox works OK..
#2 - Introduce the reverse proxy. I attempt to authenticate and I'm left with just the background of the authentication screen. I dont get taken to the image above. Are there some headers I need for nginx to make this reverse proxy function correctly?
truecommand:
image: ixsystems/truecommand:nightly
container_name: truecommand
restart: unless-stopped
networks:
- net
ports:
- 81:80
- 4343:443
volumes:
- /var/truecommand:/data
environment:
- TZ=America/Chicago
server {
listen 80;
server_name truecommand.<domain>.com;
access_log /var/log/nginx/truecommand.<domain>.com.access.log main buffer=32k;
error_log /var/log/nginx/truecommand.<domain>.error.log;
keepalive_timeout 65;
# Allow large attachments
client_max_body_size 128M;
location / {
proxy_set_header Host $host;
proxy_pass http://office.<domain>.com:81/;
proxy_redirect off;
So my problems:
