TrueNAS compile errors
Brezlord
Hi I'm trying to compile TrueNAS from source following https://github.com/truenas/core-build but I get the following errors.
[00:00:04] Warning: !!! Jail is newer than host. (Jail: 1300517, Host: 1202000) !!!
[00:00:04] Warning: This is not supported.
[00:00:04] Warning: Host kernel must be same or newer than jail.
[00:00:04] Warning: Expect build failures.
The build fails. I have tried to build on FreeBSD 12 and 13.
Current build machine is 12.2-RELEASE-p10
Any help would be appreciated.
jgreco
Resident Grinch
The host you're building on is older than the jail environment. It wants you to have a completely up-to-date FreeBSD system. Install FreeBSD 13 and then make sure you're patched up to current patchlevel.
Brezlord
I installed 13 and run
freebsd-update fetch
freebsd-update install
and it was still behind. Are the above commands correct to get 13 to the latest patch level
Thanks
jgreco
Resident Grinch
What do you have on the system now, 1300139? (output of "sysctl kern.osreldate") which is 13.0R-p4
Mmm. Curious... perhaps you have to track -STABLE? I'm actually not sure what the correct answer is here. I may try some stuff and get back to you.
Brezlord
Thanks for helping. System is 13.0-RELEASE-p4 kern.osreldate: 1300139. Stable is no good either. I'll start the build which will take some time as This is a fresh VM. I'll post the full output when done.
Brezlord
This is where it's at on 13.0-RELEASE-p4. The build will fail. How do I get the host to 1300517?
[00:00:04] Warning: !!! Jail is newer than host. (Jail: 1300517, Host: 1300139) !!!
Patrick M. Hausen
You need to update the host from source:
git clone --branch releng/13 https://git.FreeBSD.org/src.git /usr/src
cd /usr/src
make -j <ncpu> buildworld buildkernel
make installkernel
make installworld
shutdown -r now
This is an abbreviated version of the full procedure. There may be additional steps between "installkernel" and "installworld", but in case of going from RELENG_13_0 to RELENG_13 the above should work.
If you run the build environment on ZFS, create a backup boot environment before "installkernel".
HTH,
Patrick
Brezlord
The only thing to fail now is
[02:19:50] [09] [00:09:26] Finished graphics/drm-fbsd13-kmod | drm-fbsd13-kmod-5.4.92.g20210720_1: Failed: build
[02:19:51] [09] [00:09:27] Skipping graphics/drm-kmod | drm-kmod-g20190710_1: Dependent port graphics/drm-fbsd13-kmod | drm-fbsd13-kmod-5.4.92.g20210720_1 failed
Full output attached.
Any idea how I can fix the above error?
Thanks,
Simon
  • output.txt
Brezlord
I've gotten the FreeBSD build machine kernel to where it needs to be and everything works except one port fails to build. I can't work out what's wrong. Any help would be appreciated.
[ja-p] [2021-10-27_06h31m24s] [balancing_pool:] Queued: 2  Built: 0  Failed: 0  Skipped: 0  Ignored: 0  Fetched: 0  Tobuild: 2   Time: 00:00:10
[00:00:13] Recording filesystem state for prepkg... done
[00:00:13] Building 2 packages using 2 builders
[00:00:13] Starting/Cloning builders
[00:00:16] Hit CTRL+t at any time to see build progress and stats
[00:00:16] [01] [00:00:00] Building graphics/drm-fbsd13-kmod | drm-fbsd13-kmod-5.4.92.g20210720_1
[00:00:23] [01] [00:00:07] Saving graphics/drm-fbsd13-kmod | drm-fbsd13-kmod-5.4.92.g20210720_1 wrkdir
[00:00:40] [01] [00:00:24] Saved graphics/drm-fbsd13-kmod | drm-fbsd13-kmod-5.4.92.g20210720_1 wrkdir to: /usr/build/freenas/_BE/objs/ports/data/wrkdirs/ja-p/p/drm-fbsd13-kmod-5.4.92.g20210720_1.tbz
[00:00:46] [01] [00:00:30] Finished graphics/drm-fbsd13-kmod | drm-fbsd13-kmod-5.4.92.g20210720_1: Failed: build
[00:00:46] [01] [00:00:30] Skipping graphics/drm-kmod | drm-kmod-g20190710_1: Dependent port graphics/drm-fbsd13-kmod | drm-fbsd13-kmod-5.4.92.g20210720_1 failed
[00:00:46] Stopping 2 builders
[00:00:47] Creating pkg repository
Creating repository in /tmp/packages: 100%
Packing files for repository: 100%
[00:00:53] Committing packages to repository: /usr/build/freenas/_BE/objs/ports/data/packages/ja-p/.real_1635287537 via .latest symlink
[00:00:53] Removing old packages
[00:00:54] Failed ports: graphics/drm-fbsd13-kmod:build
[00:00:54] Skipped ports: graphics/drm-kmod
[ja-p] [2021-10-27_06h31m24s] [committing:] Queued: 2  Built: 0  Failed: 1  Skipped: 1  Ignored: 0  Fetched: 0  Tobuild: 0   Time: 00:00:50
[00:00:54] Logs: /usr/build/freenas/_BE/objs/ports/data/logs/bulk/ja-p/2021-10-27_06h31m24s
[00:00:54] Cleaning up
[00:00:54] Unmounting file systems
[0:04:38] ==> ERROR: Ports build failed
[0:04:38] ==> Cleaning up poudriere environment...
[0:04:38] ==> Unmounting ports overlay...
*** Error code 1
Stop.
make[2]: stopped in /usr/build
*** Error code 1
Stop.
make[1]: stopped in /usr/build
*** Error code 1
Stop.
make: stopped in /usr/build
