TrueNAS and Final Cut Pro X
moiconstantino
Unsupported Volume Type
Choose a local, SAN, or supported SMB location.
This message shows up when I try to open FCPX file, anyone knows whats going on?
Samuel Tai
Is the network drive the FCPX refers to mounted in Finder?
Samuel Tai
Should be in the same location: Sharing->Windows shares. Within the share, enable VFS fruit. Restart the SMB service to make it take effect.
Samuel Tai
What version of TrueNAS is this, and are you running in HA mode?
Samuel Tai
Don't forget to restart SMB service after changing its settings. You may also need to unmount and remount the share.
anodos
Sambassador
You're sharing out the root level dataset via AFP and SMB simultaneously.
1) Create a new dataset to share out your data (not root level).
2) When you share out same path simultaneously, we try to coordinate locking between filesharing protocols. FreeBSD lacks support for kernel oplocks and so we have to turn this feature off in the case of mixed AFP/SMB. In your case since Final Cut probably expects oplock capabilities, it fails. This means you need to _not_ share via AFP and SMB simultaneously.
moiconstantino
Do you have any tutorials or something to explain it better?
He means:
You are currently sharing like this:
Pool     <-- you are currently sharing this with both AFP and SMB
--Dataset1
--Dataset2
  --Dataset3
What he wants you to do is to share only a dataset (like Dataset1 in my example here):
Pool
--Dataset1    <-- Share this with SMB only, not AFP
--Dataset2
  --Dataset3
You can find the documentation at the top of this page and there's a chapter there on how to create a dataset if that's what's not clear.
moiconstantino
He means:
--Dataset1
--Dataset2
  --Dataset3
Pool
--Dataset2
  --Dataset3
got it.... thank you... this is my first NAS.. everything is new for me.
