Hello, I have been racking my head for a while now and I am thought I would ask the great and almighty Internet for the answers to my problem. The problem is probably so obvious that I cannot see it, but maybe you can. I have created a new TrueNAS 12.0-U8 system on bare metal. The OS is running great and I have no problems accessing the NAS via SSH, SMB, and NFS. The Plugin for Plex and Plex beta fail to install no matter how many times I try... but that is neither here no there because I have a Plex Pass so I know I will have to manually install the application anyways.
I followed the instructions to install Plex manually from here. I cannot get past the section "Access Web Interface" because my desktop cannot reach the Plex web interface. I have tried from numerous Windows systems on this very flat LAN without any security or VLANS... and yet the browsers just timeout without any response from the Plex server.
I can ping hosts on the LAN, I can reach the gateway router, I can resolve hostnames, I can also reach the Internet. I can do everything EXCEPT reach the Plex interface from my desktop.
To troubleshoot the problem I have tried every combination of creating 3 different jails with all the different combinations of:
RELEASE
12.3-RELEASE-p5 (current)
12.0-RELEASE-p13 (attempted)
11.4-RELEAE-p13 (attempted)
BASIC PROPERTIES
DHCP (attempted)
NAT (attempted)
VNET (current)
This is my CURRENT typology:
192.168.0.1 <-- Default Gateway
192.168.1.100/16 <-- igb0 <-- TrueNAS
192.168.1.101/16 <-- igb0:bridge0 <-- Plex Jail
This are my CURRENT jail settings:
(unchecked) DHCP Autoconfigure IPv4
(unchecked) NAT
(checked) VNET
(checked) Berkeley Packet Filter
vnet_default interface = igb0 (I have tried auto as well at times)
IPv4 Interface = vnet0
IPv4 Address = 192.168.1.101
IPv4 Netmask = 16
IPv4 Default Router = 192.168.0.1
(unchecked) Autoconfigure IPv6
(checked) Auto-start
My basic networking works great... but can't get the darn Plex interface to appear.
ifconfig from Plex Jail:
arp -a from my Windows desktop:
arp -a from Plex Jail:
ping google.com from Plex Jail:
netstat -a from Plex Jail:
I am not sure if there is any port security or VIP things that I have missed which would be standing in my way but if anyone has any suggestions I am ready to play the game. Thank you in advanced for your time.
RELEASE
BASIC PROPERTIES
DHCP (attempted)
NAT (attempted)
VNET (current)
(unchecked) NAT
(checked) VNET
IPv4 Netmask = 16
root@plex:~ # ifconfig lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 inet 127.0.0.1 netmask 0xff000000 groups: lo nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> pflog0: flags=0<> metric 0 mtu 33160 groups: pflog epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 26:e9:b3:14:fa:0a hwaddr 02:12:a6:02:6f:0b inet 192.168.1.101 netmask 0xffff0000 broadcast 192.168.255.255 groups: epair media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active nd6 options=1<PERFORMNUD>
Interface: 192.168.5.201 --- 0x8 Internet Address Physical Address Type 192.168.0.1 6c-ae-f6-b6-03-d2 dynamic <-- Gateway 192.168.1.100 24-e9-b3-16-08-30 dynamic <-- TrueNAS
root@plex:~ # arp -a ? (192.168.5.201) at 80:38:fb:88:84:25 on epair0b expires in 427 seconds [ethernet] ? (192.168.4.43) at 8c:5a:25:b9:8c:20 on epair0b expires in 497 seconds [ethernet] ? (192.168.0.1) at 6c:ae:f6:b6:03:d2 on epair0b expires in 1176 seconds [ethernet] ? (192.168.4.64) at 4c:12:65:f6:5e:ae on epair0b expires in 1177 seconds [ethernet]
root@plex:~ # ping google.com PING google.com (142.250.189.174): 56 data bytes 64 bytes from 142.250.189.174: icmp_seq=0 ttl=117 time=11.572 ms 64 bytes from 142.250.189.174: icmp_seq=1 ttl=117 time=11.638 ms ^C --- google.com ping statistics --- 2 packets transmitted, 2 packets received, 0.0% packet loss round-trip min/avg/max/stddev = 11.572/11.605/11.638/0.033 ms
root@plex:~ # netstat -a Active Internet connections (including servers) Proto Recv-Q Send-Q Local Address Foreign Address (state) tcp4 0 0 plex.54516 192.168.4.64.9080 TIME_WAIT tcp4 0 0 plex.18102 192.168.4.43.9080 TIME_WAIT tcp4 0 0 plex.65449 192.168.4.64.9080 TIME_WAIT tcp4 0 0 localhost.32600 *.* LISTEN tcp4 0 0 localhost.50725 localhost.35082 CLOSED tcp4 0 0 localhost.35082 *.* LISTEN tcp4 0 0 localhost.65447 localhost.27885 ESTABLISHED tcp4 1 0 localhost.27885 localhost.65447 ESTABLISHED tcp4 0 0 localhost.46921 localhost.50450 ESTABLISHED tcp4 0 0 localhost.50450 localhost.46921 ESTABLISHED tcp4 0 0 localhost.32401 *.* LISTEN tcp46 0 0 *.32400 *.* LISTEN udp4 0 0 plex.31917 *.* udp4 0 0 *.1901 *.* udp4 0 0 plex.44694 *.* udp4 0 0 plex.49199 *.* udp4 0 0 *.32413 *.* udp4 0 0 *.32412 *.* udp4 0 0 *.32410 *.* udp4 0 0 *.32414 *.* Active UNIX domain sockets Address Type Recv-Q Send-Q Inode Conn Refs Nextref Addr fffff8132f435200 dgram 0 0 0 fffff8274c72f800 0 fffff8026c5a9d00 fffff8026c5a9d00 dgram 0 0 0 fffff8274c72f800 0 0 fffff8274c72f800 dgram 0 0 fffff82731da41e0 0 fffff8132f435200 0 /var/run/logpriv fffff823673acd00 dgram 0 0 fffff82731da43c0 0 0 0 /var/run/log
