TrueNas 12.0-U1.1 - Nextcloud - help with working solution for SSL
grigoriii
i'm recently trying my skills with TrueNas and Nextcloud. I want to setup my own nextcloud with secured ssl connection. I run this on my own server in local network.
For now i can't find any working solution for secure my Nextcloud with SSL. I try for now two ways. First i install nextcloud in as plugin and try run my own certificate under trunas, but no luck, my own cloud stopped working, blank site. Second i try to install docker with portainer and try nginx but i can't generate SSL. I got error http-01 challenge failed.
Please can You help me with setting up SSL for my Nextcloud. What is the best way to make it working, secure and stable.
Thanks for help and Best Regards.
My best answer is to not use the plugin, use my script instead:
