TrueNAS-12.0 not showing share config in smb4.conf
Plaster36
TrueNAS-12.0 not showing share config in smb4.conf or smb4_share.conf
I'm not sure where I have to go to see the config at which path. The original version 9.2 will be displayed at smb.conf.
So... find /usr -name smb4.conf tells me there's a file like that here:
/usr/local/lib/python3.9/site-packages/middlewared/etc_files/local/smb4.conf
But the contents of that file are the scripts for TrueNAS to load all the stuff you're looking for from the config DB, so I don't think you'll find enlightenment there...
What you probably want is the command to show the current running config of SAMBA...
testparm -s
Plaster36
testparm -s
thank you very much
