TrueCommand Auto-Update
Want to ensure that you're always running the latest version of TrueCommand in a Docker container? Docker Compose is the enabler for automatic updates.
This technique I first used on resources for Nextcloud-OnlyOffice and Nextcloud-Collabora integration. It can be used in a more general sense with other Docker images to keep Docker containers up-to-date, but what better example to demonstrate it on in the FreeNAS forum than TrueCommand.
A check is done daily for a new version of the TrueCommand image. If a new version exists, it is downloaded and the TrueCommand container updated. The old image is then removed.
Outline of the steps
  1. Install TrueCommand using Docker Compose.
  2. Set up automatic updates.
Step 1: Install TrueCommand using Docker Compose
Install Docker Compose. This assumes you already have Docker installed on your Ubuntu host. If not, install Docker first.
In the example below, note that TrueCommand data is stored in a nested folder under the home directory i.e. $HOME/truecommand/data.
sudo docker run --detach -v "$HOME/truecommand/data:/data" -p 8080:80 -p 8081:443 --restart always --name=truecommand -e TZ=Australia/Perth ixsystems/truecommand
Run everything after sudo docker run through Composerize to convert the command to Docker-Compose format.
Change to the TrueCommand folder cd $HOME/truecommand. Create the Compose file nano docker-compose.yml and paste in the output from Composerize.
version: '3.3'
services:
    truecommand:
        volumes:
            - '$HOME/truecommand/data:/data'
        ports:
            - '8080:80'
            - '8081:443'
        restart: always
        container_name: truecommand
        environment:
            - TZ=Australia/Perth
        image: ixsystems/truecommand
Build and run TrueCommand with Compose sudo docker-compose up -d.
Step 2: TrueCommand Automatic Updates
Make sure you're in the TrueCommand folder cd $HOME/truecommand. Create the update.sh script nano update.sh and paste the following:
#!/bin/bash
date
cd "`dirname "$0"`"
docker-compose pull
docker image prune -f
date
echo
Make the file executable chmod +x update.sh.
Next, we're going to add a line, that takes the form below, to the system-wide crontab.
m h * * * /path/to/script >> /path/to/log 2>&1
Standard and error output will be appended to /path/to/log. By design, the log file will be placed in the TrueCommand folder as well, so:
/path/to/script = $HOME/truecommand/update.sh
/path/to/log = $HOME/truecommand/update.log
However, we need to use the evaluated version of $HOME for the system-wide crontab. Make a note of what this is echo $HOME.
For example:
screenshot.341
For this example:
/path/to/script = /home/administrator/truecommand/update.sh
/path/to/log = /home/administrator/truecommand/update.log
NOTE: If you've referred to environmental variables such as $HOME in the docker-compose.yml file, these will need to be replaced there as well.
Now, edit the system-wide crontab sudo crontab -e and set up the cron job.
The script should be run at a time when it's unlikely anyone will be using TrueCommand. In the example below, I'm checking for updates daily at half-past midnight.
30 0 * * *  /home/administrator/truecommand/update.sh >> /home/administrator/truecommand/update.log 2>&1
If there isn't an update when the job is run, a typical log entry will look something like the following:
screenshot.349
If an update is available, the log entry will instead look more like this:
screenshot.350
Patrick M. Hausen
Works like a charm. Applied it to my onlyoffice container, too. Thanks!
Thanks for this write-up--this is how iX should have configured the VM image to begin with. Slight quibble, though:
This assumes you already have Docker installed on your Ubuntu host. If not, you may find Step 3 of the Nextcloud-OnlyOffice resource useful.
No, it really isn't useful--step 3 in that resource just links to the FreeNAS manual, and that in turn just links to the Docker docs (and not even directly to the installation page). Suggest changing this to (1) give a link to the actual Docker installation instructions (https://docs.docker.com/engine/install/ubuntu/, since you're assuming a Ubuntu host), or (2) better yet, just include the few steps to do the installation (and while you're at it, change the deprecated apt-get to apt).
Run everything after sudo docker run through Comperize
Typo here, the name of the page is Composerize. The link is fine, just the typo in the text.
But with that said, it's up and running. Thanks again.
@danb35 I've made some changes to the OP based on your feedback. Thank you.
KevDog
Why don't you just run watchtower which does all the heavy lifting for you? This docker container automatically updates any container specified. It's a well supported project. https://github.com/containrrr/watchtower
I agree. As the number of containers increase, watchtower becomes an attractive option, however, it's probably overkill when dealing with just one or two containers.
