Robert Thomspon
- Jun 24, 2017
So, i tried installing truecharts version of nextcloud following their tutorial. i must have missed a setting or something as the app was created but got stuck at 0/3 deployed. when i navigated away from the applications page and came back, i was presented with a spinning circle. I ended up power cycling the TrueNAS machine (HUGE mistake). Now, it appears that none of my applications are launching, and all i have at the installed applications page is a spinning blue circle. Ive consulted Truecharts about this and they sent me to iX to look for help with you guys (all i REALLY wanted was a way to remove the nextcloud app that i just installed... but, there doesnt seem to be much CLI friendliness in the truecharts arena, making things really hard when you lose GUI)
Ive tried engaging with the system with docker commands (apparently a huge no no with truecharts. would be nice if they told you that.) Ive tried k3s commands as server (seems to crash), agent, kubectl, critctl (thislooked like it was going to work when i ran 'k3s critctl delete nextcloud' but it ended up timing out. also tried PID killing things, and force removing the folders that contain the pods. nothing has gotten my gui back up, but worse, the rest of the dockers (pods) arent loading either.
Truecharts is claiming this is an iXissue... so...
Anyway, attached are the info dumps Treucharts asked for. I am happy to include anything else that might help:
root@truenas[~]# service k3s status ● k3s.service - Lightweight Kubernetes Loaded: loaded (/lib/systemd/system/k3s.service; disabled; vendor preset: disabled) Active: active (running) since Wed 2022-02-09 16:56:42 EST; 1min 17s ago Docs: https://k3s.io Process: 2428415 ExecStartPre=/sbin/modprobe br_netfilter (code=exited, status=0/SUCCESS) Process: 2428416 ExecStartPre=/sbin/modprobe overlay (code=exited, status=0/SUCCESS) Main PID: 2428417 (k3s-server) Tasks: 64 Memory: 561.9M CGroup: /system.slice/k3s.service └─2428417 /usr/local/bin/k3s server Feb 09 16:57:50 truenas.local k3s[2428417]: time="2022-02-09T16:57:50.384718589-05:00" level=info ms> Feb 09 16:57:51 truenas.local k3s[2428417]: time="2022-02-09T16:57:51.384846992-05:00" level=info ms> Feb 09 16:57:52 truenas.local k3s[2428417]: time="2022-02-09T16:57:52.384974985-05:00" level=info ms> Feb 09 16:57:53 truenas.local k3s[2428417]: time="2022-02-09T16:57:53.385104291-05:00" level=info ms> Feb 09 16:57:54 truenas.local k3s[2428417]: time="2022-02-09T16:57:54.385239122-05:00" level=info ms> Feb 09 16:57:55 truenas.local k3s[2428417]: time="2022-02-09T16:57:55.385372991-05:00" level=info ms> Feb 09 16:57:56 truenas.local k3s[2428417]: time="2022-02-09T16:57:56.385491352-05:00" level=info ms> Feb 09 16:57:57 truenas.local k3s[2428417]: time="2022-02-09T16:57:57.385616779-05:00" level=info ms> Feb 09 16:57:58 truenas.local k3s[2428417]: time="2022-02-09T16:57:58.385841424-05:00" level=info ms> Feb 09 16:57:59 truenas.local k3s[2428417]: time="2022-02-09T16:57:59.386007516-05:00" level=info ms> lines 1-22/22 (END)
