Trouble updating plex on truenas scale
theman1
Any time I try to update the official plex (plexpass) version I get errors
[EFAULT] Catalog item version is not supported due to following missing features: 1) validations/lockedHostPath For 'Stable' train: Minimum SCALE version: 22.02 Maximum SCALE version: Latest available 'Stable' release For 'Nightlies' train: Minimum SCALE version: 22.02.1-MASTER Maximum SCALE version: Latest available 'Nightlies' release
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 409, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 445, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1269, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1137, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/upgrade.py", line 116, in upgrade await self.upgrade_chart_release(job, release, options) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/upgrade.py", line 251, in upgrade_chart_release await self.middleware.call('catalog.version_supported_error_check', catalog_item) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1324, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1281, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/plugins/catalogs_linux/features.py", line 75, in version_supported_error_check raise CallError(error_str) middlewared.service_exception.CallError: [EFAULT] Catalog item version is not supported due to following missing features: 1) validations/lockedHostPath For 'Stable' train: Minimum SCALE version: 22.02 Maximum SCALE version: Latest available 'Stable' release For 'Nightlies' train: Minimum SCALE version: 22.02.1-MASTER Maximum SCALE version: Latest available 'Nightlies' release
