SOLVED Trouble setting up rc.conf
Discolai
Hi, I am having some trouble setting up rc.conf to run my ts3 server script. I placed the script in /usr/local/etc/rc.d and I am able to start the script with service ts3server onsestart, so the script runs fine by itself.
I have set teamspeak_enable="YES" in /etc/rc.conf, but when I run service ts3server rcvar I get this output:
#ts3server
teamspeak_enable=""
#    (default: "")
  • ts3server_service.zip
nojohnny101
in your rc.conf file, try this:
ts3server_enable="YES"
Are you doing this in a jail?
If you are editing the rc.conf of the FreeNAS host you won't get a lot of joy as it is re-written based on the config database.
It is generally a terrible idea to run applications directly on a FreeNAS host... always use jails.
If you're already in a jail it may me useful to go to a command prompt in the jail and run sysrc -a to see what's actually being seen there.
Discolai
Yes, I forgot to mention that it is running inside a jail. I ran the sysrc -a command which showed that it could see the rcvar, this made me think that there was something wrong with my script. I followed this guide when I created the script, but I had forgotten load_rc_config. I added the command and then it was able to read the rcvar properly.
