I have a server that I want to use as an ISCSI target, and I'm new to freenas. It seems pretty straightforward, but when I go to Add Extent under Device Extents and I add my intended drive (which is da1), it acts like it is going to add, but then it shows up as added da0. If I add da3, it does the same thing - it adds da2 instead.
The server is an HP ML370, set up with hardware raid with 2 controllers. da0 and 1 are on controller 1, da2 and 3 are on controller 2. da0 and 2 are set up as the first set of disks which are 72G drives in a RAID1 config, and da1 and 3 are the 2nd set of disks (6x146G set up in a R5).
It's really weird - I'm wondering if it's not fully seeing these 2nd set of disks? (Even though they are an option in the drop down.)
Now the odd thing is if I configure the 2nd disks as my extents, then if I go to add extent the only ones that show up are the first set (So it's like it really is using them, it's just not showing correctly on the main page.) So is this a bug? And is there a way to know if the extent that shows a path of /dev/da0 is actually /dev/da1?
