unca_NAS
- Mar 25, 2012
Hello
Have transmission running in jail. In the same jail is OpenVPN running. Transmissions traffic goes thru VPN.
Port-forwarding port 51413 was easy task when TransM was running without VPN. Im pretty sure that it can be done - but how?
EDIT:
After some googling bumped into a VPN-providers (Private Internet Access) script for linux, thats suppose to solve the problem. Is it possible to modify the script in a way that it can be run within a plugin jail?
Played a little with it (if-statement commented) results "Loading port forward assignment information..." than terminates without returning the port number..
EDIT:
#! /bin/bash # # Enable port forwarding # # Requirements: # your Private Internet Access user and password as arguments # # Usage: # ./port_forward.sh <user> <password> error( ) { echo "$@" 1>&2 exit 1 } error_and_usage( ) { echo "$@" 1>&2 usage_and_exit 1 } usage( ) { echo "Usage: `dirname $0`/$PROGRAM <user> <password>" } usage_and_exit( ) { usage exit $1 } version( ) { echo "$PROGRAM version $VERSION" } port_forward_assignment( ) { echo 'Loading port forward assignment information..' # if [ "$(uname)" == "Linux" ]; then #local_ip=`ifconfig tun0|grep -oE "inet addr: *10\.[0-9]+\.[0-9]+\.[0-9]+"|tr -d "a-z :"|tee /tmp/vpn_ip` #client_id=`head -n 100 /dev/urandom | md5sum | tr -d " -"` #fi #if [ "$(uname)" == "Darwin" ]; then local_ip=`ifconfig tun0 | grep "inet " | cut -d\ -f2|tee /tmp/vpn_ip` client_id=`head -n 100 /dev/urandom | md5 -r | tr -d " -"` #fi json=`wget -q --post-data="user=$USER&pass=$PASSWORD&client_id=$client_id&local_ip=$local_ip" -O - 'https://www.privateinternetaccess.com/vpninfo/port_forward_assignment' | head -1` echo $json } EXITCODE=0 PROGRAM=`basename $0` VERSION=1.0 USER=$1 PASSWORD=$2 while test $# -lt 2 do case $1 in --usage | --help | -h ) usage_and_exit 0 ;; --version | -v ) version exit 0 ;; *) error_and_usage "Unrecognized option: $1" ;; esac shift done port_forward_assignment exit 0
