Hi everyone!
New to FreeNAS! I had been using for the past few another similar OS, but I decided it was time to try FreeNAS.
On my previous NAS4Free setup, I had been using Plex, Transmission and ownCloud, and they were all working just fine.
Now on FreeNAS, I unfortunatelly have some issues, which could be related to the fact that I am unfamiliar with this OS.
ownCloud
I installed ownCloud using the Plugin manager. I then went to https://192.168.1.21 (local IP of my onwCloud server), and I set up some thing I wanted to.
The problem I have, is that when I try to connect through my Android app, I get a "SSL initialization failed" error, which prohibits me from accessing my files.
I spent some time searching on the Internet, but to be honest, I couldn't figure out how to fix this.
When on NAS4Free, I was using selfprovided certificate (everything was working fine with this), but now I am using the default one.
I'd like also to know, which is the default port that ownCloud (192.168.1.21:XX) runs.
Transmission
Once, again, I installed Transmission using the Plugin manager.
The problem here is that I get a "Permission Denied" error whenever I try to download something.
Here's how I set this plugin up.
I created a Datasheet on my Data volume (mnt/Data/torrents), and gave full permissions to owner (root) group (wheel) others.
After reading a FreeNAS wiki, I changed some directories on Transmission settings like this
but unfortunately, the error is still there.
I know that these errors may be common or already replied, but I even though I searched, I couldn't find anything that could help me fix them.
Any help will be appreciated. Thanks!
ownCloud
Transmission
