Ok so I've got a new server and I'm trying to recreate what I have running on my old server. My old is running TrueNAS Core 12.0 U8 with transmission plugin running OpenVPN on top with PIA, without issues. I spun up a new TrueNAS Core 12.0 U8 but it seemed like the jail would lose connection / DNS after OpenVPN connected. I tried a bunch of stuff to no avail. I even exported the jail working in my old server, imported it, did the changes required for the fstab for the jail, got it to start, but same thing, appeared to lose connection / DNS. Even creating a new transmission jail on the old server does the same, as in it doesn't work but the old jail works fine.
So currently I spun up a new TrueNAS Core 13.0 U3 (fresh, only setup a storage pool, and transmission jail, that's all), ran through the normal setup for transmission and OpenVPN, and still run into the same issue. /var/log/messages does show something about ipv6 not configured but my old server has those messages as well so it's unrelated.
I'm willing to try all suggestions on the new setup to get this working.
Here is how I went about ssetting up OpenVPN in the transmission jail;
Can't ping my router but can ping google.ca (got the IP from a ping on my other server)
Edit:
I forgot to note that the new TrueNAS and the jail are using DHCP just for keeping things simple until there is a working solution. There are no subnets in use, straight forward home network Bell Fiber.
root@truenas[~]# jexec 1 tcsh root@transmisssion:/ # pkg update Updating iocage-plugins repository catalogue... iocage-plugins repository is up to date. All repositories are up to date. root@transmisssion:/ # pkg upgrade Updating iocage-plugins repository catalogue... iocage-plugins repository is up to date. All repositories are up to date. Checking for upgrades (0 candidates): 100% Processing candidates (0 candidates): 100% Checking integrity... done (0 conflicting) Your packages are up to date. root@transmisssion:/ # pkg install -y wget openvpn Updating iocage-plugins repository catalogue... iocage-plugins repository is up to date. All repositories are up to date. The following 6 package(s) will be affected (of 0 checked): New packages to be INSTALLED: easy-rsa: 3.1.2 liblz4: 1.9.4,1 lzo2: 2.10_1 openvpn: 2.6.0 pkcs11-helper: 1.29.0 wget: 1.21.3_1 Number of packages to be installed: 6 The process will require 7 MiB more space. 2 MiB to be downloaded. [transmisssion] [1/6] Fetching wget-1.21.3_1.pkg: 100% 687 KiB 703.9kB/s 00:01 [transmisssion] [2/6] Fetching openvpn-2.6.0.pkg: 100% 580 KiB 593.5kB/s 00:01 [transmisssion] [3/6] Fetching liblz4-1.9.4,1.pkg: 100% 145 KiB 148.0kB/s 00:01 [transmisssion] [4/6] Fetching pkcs11-helper-1.29.0.pkg: 100% 95 KiB 97.8kB/s 00:01 [transmisssion] [5/6] Fetching lzo2-2.10_1.pkg: 100% 113 KiB 115.7kB/s 00:01 [transmisssion] [6/6] Fetching easy-rsa-3.1.2.pkg: 52% 32 KiB 32.8kB/s 00[transmisssion] [6/6] Fetching easy-rsa-3.1.2.pkg: 100% 61 KiB 62.5kB/s 00:01 Checking integrity... done (0 conflicting) [transmisssion] [1/6] Installing liblz4-1.9.4,1... [transmisssion] [1/6] Extracting liblz4-1.9.4,1: 100% [transmisssion] [2/6] Installing pkcs11-helper-1.29.0... [transmisssion] [2/6] Extracting pkcs11-helper-1.29.0: 100% [transmisssion] [3/6] Installing lzo2-2.10_1... [transmisssion] [3/6] Extracting lzo2-2.10_1: 100% [transmisssion] [4/6] Installing easy-rsa-3.1.2... [transmisssion] [4/6] Extracting easy-rsa-3.1.2: 100% [transmisssion] [5/6] Installing wget-1.21.3_1... [transmisssion] [5/6] Extracting wget-1.21.3_1: 100% [transmisssion] [6/6] Installing openvpn-2.6.0... ===> Creating groups. Creating group 'openvpn' with gid '301'. ===> Creating users Creating user 'openvpn' with uid '301'. [transmisssion] [6/6] Extracting openvpn-2.6.0: 100% ===== Message from easy-rsa-3.1.2: -- NOTE: easy-rsa will require you to initialize a pki ONLY UPON FIRST USE. The packaging itself no longer does this because that would confuse easy-rsa, and easy-rsa expects the vars not to be per-installation, but per-PKI. ONLY for the very first run for a new PKI, do something such as: easyrsa --pki-dir=~/my_new_pki init-pki # DANGEROUS - DESTROYS ~/my_new_pki which will copy vars.example both into ~/my_new_pki and create another copy named ~/my/new_pki/vars for you to edit for this PKI. Then, edit ~/my/new_pki/vars to set the defaults. After upgrades, use other commands, explained by running: easyrsa help. to explain options such as --pki-dir (see above), run: easyrsa help options ===== Message from openvpn-2.6.0: -- Edit /etc/rc.conf[.local] to start OpenVPN automatically at system startup. See /usr/local/etc/rc.d/openvpn for details. Connect to VPN server as a client with this command to include the client.up/down scripts in the initialization: openvpn-client <spec>.ovpn For compatibility notes when interoperating with older OpenVPN versions, please see <http://openvpn.net/relnotes.html> Note that OpenVPN does not officially support LibreSSL. Note that OpenVPN configures a separate user and group "openvpn", which should be used instead of the NFS user "nobody" when an unprivileged user account is desired. You may want to add user openvpn and group openvpn when creating your configuration files, the example configuration shows this only as comments. root@transmisssion:/ # cat > /etc/rc.conf.d/openvpn openvpn_enable="YES" openvpn_configfile="/usr/local/etc/openvpn/openvpn.conf" ^C root@transmisssion:/ # cd /tmp root@transmisssion:/tmp # mkdir openvpn;cd openvpn root@transmisssion:/tmp/openvpn # wget https://www.privateinternetaccess.com/openvpn/openvpn.zip --2023-03-06 12:11:31-- https://www.privateinternetaccess.com/openvpn/openvpn.zip Resolving www.privateinternetaccess.com (www.privateinternetaccess.com)... 104.18.14.49, 104.18.15.49 Connecting to www.privateinternetaccess.com (www.privateinternetaccess.com)|104.18.14.49|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 192173 (188K) [application/zip] Saving to: ‘openvpn.zip’ openvpn.zip 100%[===================>] 187.67K --.-KB/s in 0.07s 2023-03-06 12:11:31 (2.55 MB/s) - ‘openvpn.zip’ saved [192173/192173] root@transmisssion:/tmp/openvpn # unzip openvpn.zip Archive: openvpn.zip extracting: albania.ovpn extracting: algeria.ovpn extracting: andorra.ovpn extracting: argentina.ovpn extracting: armenia.ovpn extracting: au_melbourne.ovpn extracting: au_perth.ovpn extracting: au_sydney.ovpn extracting: austria.ovpn extracting: bahamas.ovpn extracting: bangladesh.ovpn extracting: belgium.ovpn extracting: brazil.ovpn extracting: bulgaria.ovpn extracting: ca.rsa.2048.crt extracting: ca_montreal.ovpn extracting: ca_ontario.ovpn extracting: ca_toronto.ovpn extracting: ca_vancouver.ovpn extracting: cambodia.ovpn extracting: china.ovpn extracting: crl.rsa.2048.pem extracting: cyprus.ovpn extracting: czech_republic.ovpn extracting: de_berlin.ovpn extracting: de_frankfurt.ovpn extracting: denmark.ovpn extracting: egypt.ovpn extracting: estonia.ovpn extracting: finland.ovpn extracting: france.ovpn extracting: georgia.ovpn extracting: greece.ovpn extracting: greenland.ovpn extracting: hong_kong.ovpn extracting: hungary.ovpn extracting: iceland.ovpn extracting: india.ovpn extracting: ireland.ovpn extracting: isle_of_man.ovpn extracting: israel.ovpn extracting: italy.ovpn extracting: japan.ovpn extracting: kazakhstan.ovpn extracting: latvia.ovpn extracting: liechtenstein.ovpn extracting: lithuania.ovpn extracting: luxembourg.ovpn extracting: macao.ovpn extracting: macedonia.ovpn extracting: malta.ovpn extracting: mexico.ovpn extracting: moldova.ovpn extracting: monaco.ovpn extracting: mongolia.ovpn extracting: montenegro.ovpn extracting: morocco.ovpn extracting: netherlands.ovpn extracting: new_zealand.ovpn extracting: nigeria.ovpn extracting: norway.ovpn extracting: panama.ovpn extracting: philippines.ovpn extracting: poland.ovpn extracting: portugal.ovpn extracting: qatar.ovpn extracting: romania.ovpn extracting: saudi_arabia.ovpn extracting: serbia.ovpn extracting: singapore.ovpn extracting: slovakia.ovpn extracting: south_africa.ovpn extracting: spain.ovpn extracting: sri_lanka.ovpn extracting: sweden.ovpn extracting: switzerland.ovpn extracting: taiwan.ovpn extracting: turkey.ovpn extracting: uk_london.ovpn extracting: uk_manchester.ovpn extracting: uk_southampton.ovpn extracting: ukraine.ovpn extracting: united_arab_emirates.ovpn extracting: us_atlanta.ovpn extracting: us_california.ovpn extracting: us_chicago.ovpn extracting: us_denver.ovpn extracting: us_east.ovpn extracting: us_florida.ovpn extracting: us_houston.ovpn extracting: us_las_vegas.ovpn extracting: us_new_york.ovpn extracting: us_seattle.ovpn extracting: us_silicon_valley.ovpn extracting: us_texas.ovpn extracting: us_washington_dc.ovpn extracting: us_west.ovpn extracting: venezuela.ovpn extracting: vietnam.ovpn root@transmisssion:/tmp/openvpn # sed -i .bak 's/auth-user-pass/auth-user-pass pass.txt/' ca_toronto.ovpn root@transmisssion:/tmp/openvpn # printf "ID\nPASS\n" > pass.txt root@transmisssion:/tmp/openvpn # mkdir /usr/local/etc/openvpn/ root@transmisssion:/tmp/openvpn # cp ca.rsa.2048.crt crl.rsa.2048.pem pass.txt /usr/local/etc/openvpn/ root@transmisssion:/tmp/openvpn # cp ca_toronto.ovpn /usr/local/etc/openvpn/openvpn.conf root@transmisssion:/tmp/openvpn # pkg search speedtest py39-speedtest-cli-2.1.3 Command line interface for testing internet bandwidth root@transmisssion:/tmp/openvpn # pkg install -y py39-speedtest-cli-2.1.3 Updating iocage-plugins repository catalogue... iocage-plugins repository is up to date. All repositories are up to date. The following 6 package(s) will be affected (of 0 checked): New packages to be INSTALLED: libffi: 3.4.4 mpdecimal: 2.5.1 py39-setuptools: 63.1.0 py39-speedtest-cli: 2.1.3 python39: 3.9.16_2 readline: 8.2.0 Number of packages to be installed: 6 The process will require 132 MiB more space. 19 MiB to be downloaded. [transmisssion] [1/6] Fetching py39-setuptools-63.1.0.pkg: 47% 512 KiB 524.3kB[transmisssion] [1/6] Fetching py39-setuptools-63.1.0.pkg: 100% 1 MiB 1.1MB/s 00:01 [transmisssion] [2/6] Fetching mpdecimal-2.5.1.pkg: 84% 272 KiB 278.5kB/s 0[transmisssion] [2/6] Fetching mpdecimal-2.5.1.pkg: 100% 320 KiB 327.7kB/s 00:01 [transmisssion] [3/6] Fetching python39-3.9.16_2.pkg: 3% 696 KiB 712.7kB/s [transmisssion] [3/6] Fetching python39-3.9.16_2.pkg: 12% 2 MiB 1.6MB/s [transmisssion] [3/6] Fetching python39-3.9.16_2.pkg: 26% 5 MiB 2.5MB/s [transmisssion] [3/6] Fetching python39-3.9.16_2.pkg: 43% 8 MiB 3.2MB/s [transmisssion] [3/6] Fetching python39-3.9.16_2.pkg: 66% 12 MiB 4.2MB/s [transmisssion] [3/6] Fetching python39-3.9.16_2.pkg: 92% 16 MiB 4.8MB/s [transmisssion] [3/6] Fetching python39-3.9.16_2.pkg: 100% 18 MiB 3.1MB/s 00:06 [transmisssion] [4/6] Fetching py39-speedtest-cli-2.1.3.pkg: 100% 36 KiB 37.0kB/s 00:01 [transmisssion] [5/6] Fetching libffi-3.4.4.pkg: 100% 42 KiB 42.5kB/s 00:01 [transmisssion] [6/6] Fetching readline-8.2.0.pkg: 6% 24 KiB 24.6kB/s 00[transmisssion] [6/6] Fetching readline-8.2.0.pkg: 100% 367 KiB 376.1kB/s 00:01 Checking integrity... done (0 conflicting) [transmisssion] [1/6] Installing mpdecimal-2.5.1... [transmisssion] [1/6] Extracting mpdecimal-2.5.1: 100% [transmisssion] [2/6] Installing libffi-3.4.4... [transmisssion] [2/6] Extracting libffi-3.4.4: 100% [transmisssion] [3/6] Installing readline-8.2.0... [transmisssion] [3/6] Extracting readline-8.2.0: 100% [transmisssion] [4/6] Installing python39-3.9.16_2... [transmisssion] [4/6] Extracting python39-3.9.16_2: 100% [transmisssion] [5/6] Installing py39-setuptools-63.1.0... [transmisssion] [5/6] Extracting py39-setuptools-63.1.0: 100% [transmisssion] [6/6] Installing py39-speedtest-cli-2.1.3... [transmisssion] [6/6] Extracting py39-speedtest-cli-2.1.3: 100% ===== Message from python39-3.9.16_2: -- Note that some standard Python modules are provided as separate ports as they require additional dependencies. They are available as: py39-gdbm databases/py-gdbm@py39 py39-sqlite3 databases/py-sqlite3@py39 py39-tkinter x11-toolkits/py-tkinter@py39 root@transmisssion:/tmp/openvpn # wget -qO - http://wtfismyip.com/text 47.54.237.64 root@transmisssion:/tmp/openvpn # speedtest Retrieving speedtest.net configuration... Testing from Bell Canada (x.x.x.x)... #edited to hide public address Retrieving speedtest.net server list... Selecting best server based on ping... Hosted by Bell Aliant (Moncton, NB) [138.82 km]: 6.264 ms Testing download speed................................................................................ Download: 847.14 Mbit/s Testing upload speed...................................................................................................... Upload: 409.57 Mbit/s root@transmisssion:/tmp/openvpn # service openvpn start Starting openvpn. root@transmisssion:/tmp/openvpn # wget -qO - http://wtfismyip.com/text ^C root@transmisssion:/tmp/openvpn # ping google.ca ping: Unknown host root@transmisssion:/tmp/openvpn #
root@transmisssion:/tmp/openvpn # ping 192.168.2.1 PING 192.168.2.1 (192.168.2.1): 56 data bytes ^C --- 192.168.2.1 ping statistics --- 11 packets transmitted, 0 packets received, 100.0% packet loss root@transmisssion:/tmp/openvpn # ping 142.250.64.67 PING 142.250.64.67 (142.250.64.67): 56 data bytes 64 bytes from 142.250.64.67: icmp_seq=0 ttl=117 time=55.471 ms 64 bytes from 142.250.64.67: icmp_seq=1 ttl=117 time=52.622 ms 64 bytes from 142.250.64.67: icmp_seq=2 ttl=117 time=52.597 ms
Edit:
