I just wanted to point out for future reference that this isn't a command related to any plug-in. By reading the syntax usage of this command by running
It's running sysrc using the value of "transmission_download_dir=/media/complete” as a parameter which adds that configuration variable into /etc/rc.conf by default.
And to see every config variable use a capitalized letter A instead.
One last thing I wanted to add, if anyone is using Couch Potato as well, make sure you're not specifying a download directory on that side, otherwise you probably end up in a place like this.
SYSRC(8) FreeBSD System Manager's Manual SYSRC(8)
NAME
sysrc – safely edit system rc files
SYNOPSIS
sysrc [-cdDeEFhinNqvx] [-s name] [-f file] [-j jail | -R dir]
name[[+|-]=value] ...
sysrc [-cdDeEFhinNqvx] [-s name] [-f file] [-j jail | -R dir] -a | -A
sysrc [-E] [-s name] [-f file] -l
sysrc [-eEqv] -L [name ...]
DESCRIPTION
The sysrc utility retrieves rc.conf(5) variables from the collection of
system rc files and allows processes with appropriate privilege to change
values in a safe and effective manner.
The following options are available:
-a Dump a list of all non-default configuration variables.
-A Dump a list of all configuration variables (incl. defaults).
-c Check only. For querying, return success if all requested
variables are set (even if NULL), otherwise return error status.
For assignments, return success if no changes are required,
otherwise failure. If verbose (see “-v”) prints a message
stating whether variables are set and/or changes are required.
-d Print a description of the given variable.
-D Show default value(s) only (this is the same as setting RC_CONFS
to NULL or passing `-f' with a NULL file-argument).
-e Print query results as sh(1) compatible syntax (for example,
‘var=value’). Ignored if either ‘-n’ or ‘-F’ is specified.
-E When given ‘-l’ or ‘-L’ to list configuration files, only list
those that exist. When changing a setting, prefer to modify
existing files.
-f file Operate on the specified file(s) instead of the files obtained
by reading the ‘rc_conf_files’ entry in the RC_DEFAULTS file.
This option can be specified multiple times for additional
files.
-F Show only the last rc.conf(5) file each directive is in.
-h Print a short usage message to stderr and exit.
--help Print a full usage statement to stderr and exit.
-i Ignore unknown variables.
-j jail The jid or name of the jail to operate within (overrides ‘-R
dir’; requires jexec(8)).
-l List configuration files used at startup on stdout and exit.
-L List all configuration files including rc.conf.d entries on
stdout and exit. Can be combined with ‘-v’ or ‘-e’ to show
service names. sysrc exits with success if all named services
are installed, failure otherwise.
-n Show only variable values, not their names.
-N Show only variable names, not their values.
-q Quiet. Disable verbose and hide certain errors. When combined
with ‘-L’ and one or more name arguments, provide only exit
status and no output.
-R dir Operate within the root directory ‘dir’ rather than ‘/’.
-s name If an rc.d script of name exists (in “/etc/rc.d” or
local_startup directories), process its “rc.conf.d” entries as
potential overrides to ‘rc_conf_files’. See rc.subr(8) for
additional information on “rc.conf.d”. Can be combined with
‘-l’ to list configuration files used by service at startup.
-v Verbose. Print the pathname of the specific rc.conf(5) file
where the directive was found.
--version
Print version information to stdout and exit.
-x Remove variable(s) from specified file(s).
This utility has a similar syntax to sysctl(8). It shares the `-e' and
`-n' options (detailed above) and also has the same ‘name[=value]’ syntax
for making queries/assignments. In addition (but unlike sysctl(8)),
‘name+=value’ is supported for adding items to values (see APPENDING
VALUES) and ‘name-=value’ is supported for removing items from values
(see SUBTRACTING VALUES).
However, while sysctl(8) serves to query/modify MIBs in the entrant
kernel, sysrc instead works on values in the system rc.conf(5)
configuration files.
The list of system configuration files is configured in the file
‘/etc/defaults/rc.conf’ within the variable ‘rc_conf_files’, which by-
default contains a space-separated list of pathnames. On all FreeBSD
systems, this defaults to the value "/etc/rc.conf /etc/rc.conf.local".
Each pathname is sourced in-order upon startup. It is in the same
fashion that sysrc sources the configuration files before returning the
value of the given variable.
When supplied a variable name, sysrc will return the value of the
variable. If the variable does not appear in any of the configured
‘rc_conf_files’, an error is printed and error status is returned.
When changing values of a given variable, it does not matter if the
variable appears in any of the ‘rc_conf_files’ or not. If the variable
does not appear in any of the files, it is appended to the end of the
first pathname in the ‘rc_conf_files’ variable. Otherwise, sysrc will
replace only the last-occurrence in the last-file found to contain the
variable. This gets the value to take effect next boot without heavily
modifying these integral files (yet taking care not to allow the file to
grow unwieldy should sysrc be called repeatedly).
APPENDING VALUES
When using the ‘key+=value’ syntax to add items to existing values, the
first character of the value is taken as the delimiter separating items
(usually " " or ","). For example, in the following statement:
sysrc cloned_interfaces+=" gif0"
the first character is a space, informing sysrc that existing values are
to be considered separated by whitespace. If ‘gif0’ is not found in the
existing value for cloned_interfaces, it is added (with delimiter only if
existing value is non-NULL).
For convenience, if the first character is alpha-numeric (letters A-Z,
a-z, or numbers 0-9), dot () ., or slash (/), sysrc uses the default
setting of whitespace as separator. For example, the above and below
statements are equivalent since “gif0” starts with an alpha-numeric
character (the letter g):
sysrc cloned_interfaces+=gif0
Take the following sequence for example:
sysrc cloned_interfaces= # start with NULL
# NULL -> `gif0' (NB: no preceding delimiter)
sysrc cloned_interfaces+=gif0 # no change
sysrc cloned_interfaces+="tun0 gif0"
# `gif0' -> `gif0 tun0' (NB: no duplication)
sysrc prevents the same value from being added if already there.
SUBTRACTING VALUES
When using the ‘key-=value’ syntax to remove items from existing values,
the first character of the value is taken as the delimiter separating
items (usually " " or ","). For example, in the following statement:
cloned_interfaces-=" gif0"
to be considered separated by whitespace. If ‘gif0’ is found in the
existing value for cloned_interfaces, it is removed (extra delimiters
removed).
sysrc cloned_interfaces-=gif0
sysrc foo="bar baz" # start
sysrc foo-=bar # `bar baz' -> `baz'
sysrc foo-=baz # `baz' -> NULL
sysrc removes all occurrences of all items provided and collapses extra
delimiters between items.
ENVIRONMENT
The following environment variables are referenced by sysrc:
RC_CONFS Override default ‘rc_conf_files’ (even if set to NULL).
RC_DEFAULTS Location of ‘/etc/defaults/rc.conf’ file.
DEPENDENCIES
The following standard commands are required by sysrc:
awk(1), cat(1), chmod(1), env(1), grep(1), mktemp(1), mv(1), rm(1),
sh(1), stat(1), tail(1), chown(8), jls(8), and jexec(8).
FILES
/etc/rc.conf
/etc/rc.conf.local
/etc/rc.conf.d/name
/etc/rc.conf.d/name/*
/usr/local/etc/rc.conf.d/name
/usr/local/etc/rc.conf.d/name/*
EXAMPLES
Below are some simple examples of how sysrc can be used to query certain
values from the rc.conf(5) collection of system configuration files:
sysrc sshd_enable
returns the value of $sshd_enable, usually YES or NO.
sysrc defaultrouter
returns IP address of default router (if configured).
Working on other files, such as crontab(5):
sysrc -f /etc/crontab MAILTO
returns the value of the MAILTO setting (if configured).
Appending to existing values:
appends "gif0" to $cloned_interfaces (see APPENDING VALUES).
removes "gif0" from $cloned_interfaces (see SUBTRACTING VALUES).
In addition to the above syntax, sysrc also supports inline sh(1)
PARAMETER expansion for changing the way values are reported, shown
below:
sysrc 'hostname%%.*'
returns $hostname up to (but not including) first `.'.
sysrc 'network_interfaces%%[$IFS]*'
returns first word of $network_interfaces.
sysrc 'ntpdate_flags##*[$IFS]'
returns last word of $ntpdate_flags (time server address).
sysrc usbd_flags-"default"
returns $usbd_flags or default if unset or NULL.
sysrc cloned_interfaces+"alternate"
returns alternate if $cloned_interfaces is set.
SEE ALSO
rc.conf(5), rc.subr(8), jail(8), jexec(8), jls(8), rc(8), sysctl(8)
HISTORY
A sysrc utility first appeared in FreeBSD 9.2.
AUTHORS
Devin Teske <dteske@FreeBSD.org>
THANKS TO
Brandon Gooch, Ngie Cooper, Julian Elischer, Pawel Jakub Dawidek, Cyrille
Lefevre, Ross West, Stefan Esser, Marco Steinbach, Jilles Tjoelker, Allan
Jude, and Lars Engels for suggestions, help, and testing.
FreeBSD 11.2-STABLE February 2, 2016 FreeBSD 11.2-STABLE
