Took apart last attempt at FreeNAS, new parts
silvergoat
I decided to take apart my previous FreeNAS system which wasn't transferring content at a speed I thought would be sufficient for HD content (haven't figured out if I will use compressed or uncompressed yet).
Previous system was Celeron E3300, 4GB DDR2 RAM, 4 WD VRaptors in stripe, gzip compression = 6, ASUS P5KPL-AM EPU board, Intel Gigabit CT
I just ordered some new drives because the previous test run would not give me nearly enough room and I will be working with 5 WD Red 2TB drives in raidz1. The newer system will also use: Gigabyte EP45-UD3R board, Q6600@3.2GHz, 8GB DDR2 RAM, Intel Gigabit CT-
I haven't decided if I will need or use compression. With the previous system @gzip=6, I was saving about 8-9% which gave me pretty much the same storage as a pre-formatted drive. I will be using slower drives so I think I will want to maximize hard drive throughput, and I'm not sure if eliminating compression will help. The file format I am likely to use most is going to be .mkv and almost all content will be video......mostly standard DVD source.
Are there any recommendations for configuration before I start putting this together? My main problem with the first system is that I would max out at ~65MB/s read/writes from the server......which is no better than I was getting with 2 mirrored standard 7200rpm drives so I settled on slower drives and faster equipment to remove the bottleneck and save money.....hopefully getting closer to the max throughput on the raidz1 setup.
fracai
Set up different datasets for different types of data. I now have my whole pool set to use the default compression (I don't see, nor do I really expect to see anything better than 1x for the compression ratio), but I have my email backup and jail set to gzip-9. I think mail is around 1.5x, jail software is 2x, and the jail system is almost 5x.
When I experimented with different compression formats and video data I did see compression gains, but they were hardly worthwhile. That's why I set the main pool to the default compression (processor efficient and maybe I'll see a bit of i/o gain from the compressed blocks) and used more intensive algorithms for the datasets that I knew would see better ratios.
silvergoat
I'm pretty sure I will not be using compression, so, is there any specific file format that works best for streaming? I have all my TV DVDs in MKV format, I don't like to do a lot of handbrake conversion because things never come out exactly the way I want them......problems pop up here and there, and I don't have the time to watch everything I transcode, to make sure it's all synced okay.
What do you prefer for storage/streaming format- VOB, ISO, MKV, something else?
fracai
To be honest, my files are whatever I happened to like at the time that I made the encode. If I were doing things now, everything would probably be h264 MP4s. MKV is fine, but MP4 is supported by AppleTV. I do have several ISOs for DVD images, but when I get the time I think I'll be converting all of these to single title MP4 (with commentary tracks as appropriate).
Steve Salier
I run FreeNAS 8.3 on an E3300 with 2 GB RAM, 1 x 1GB interface and 4 x Seagate 7200.14 3TB drives, RAIDZ and no compression and can stream mounted blue-ray ISO's over CIFS mounted on a HTPC with no issues whatsoever ....
silvergoat
Half of the drives are bad, so I'll be waiting about another week before it goes together.
As I understand it, HTPC requires a video card to do the processing for video- I can do that, but how would this affect it's function as a file server? I think HTPC requires the PC be connected to a TV. I don't have any TV, I just want this accessible at any PC or via xbox for TVs.
I would need to budget for another video card as well, so HTPC is almost entirely out of the question since I've burned out the budget for a while on the new drives.
Top Bottom
