- Aug 16, 2011
So a few days ago, I upgraded my FreeNAS 11.3-Usomething (U4.1, I think) box to TN 12.0-U1. The upgrade was uneventful, jails are still working, shares are still working, etc. Then I thought it'd be good to upgrade my jails, so going through my list, I started running
Trying it with 12.1-RELEASE gives the same result, as does 12.0-RELEASE. A little baffled here. Just to make sure I wasn't mis-typing something, or doing something different, I scrolled up in my shell history to pull the exact command I'd been using--still the same result. And today, a day later, I'm still seeing the same thing. Any ideas what's going on, or how to correct it?
iocage upgrade -r 12.2-RELEASE <jailname>
on them, one at a time. Of course, the iocage upgrade
takes a while, so after four of them, I went to bed. The next day, running the same command won't work:Code:
root@freenas2[~]# iocage upgrade -r 12.2-RELEASE emby Traceback (most recent call last): File "/usr/local/bin/iocage", line 10, in <module> sys.exit(cli()) File "/usr/local/lib/python3.8/site-packages/click/core.py", line 764, in __call__ return self.main(*args, **kwargs) File "/usr/local/lib/python3.8/site-packages/click/core.py", line 717, in main rv = self.invoke(ctx) File "/usr/local/lib/python3.8/site-packages/click/core.py", line 1137, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File "/usr/local/lib/python3.8/site-packages/click/core.py", line 956, in invoke return ctx.invoke(self.callback, **ctx.params) File "/usr/local/lib/python3.8/site-packages/click/core.py", line 555, in invoke return callback(*args, **kwargs) File "/usr/local/lib/python3.8/site-packages/iocage_cli/upgrade.py", line 40, in cli ioc.IOCage(jail=jail, skip_jails=skip_jails).upgrade(release) File "/usr/local/lib/python3.8/site-packages/iocage_lib/iocage.py", line 2070, in upgrade new_release = ioc_upgrade.IOCUpgrade( File "/usr/local/lib/python3.8/site-packages/iocage_lib/ioc_upgrade.py", line 110, in upgrade_jail with urllib.request.urlopen(f) as fbsd_update: File "/usr/local/lib/python3.8/urllib/request.py", line 222, in urlopen return opener.open(url, data, timeout) File "/usr/local/lib/python3.8/urllib/request.py", line 531, in open response = meth(req, response) File "/usr/local/lib/python3.8/urllib/request.py", line 640, in http_response response = self.parent.error( File "/usr/local/lib/python3.8/urllib/request.py", line 569, in error return self._call_chain(*args) File "/usr/local/lib/python3.8/urllib/request.py", line 502, in _call_chain result = func(*args) File "/usr/local/lib/python3.8/urllib/request.py", line 649, in http_error_default raise HTTPError(req.full_url, code, msg, hdrs, fp) urllib.error.HTTPError: HTTP Error 404: Not Found
