Hello!
I had a problem, where a debian-VM had a time of +2h relative to the host machine. This is problematic for some services, like resilio-sync that rely on accurate time and date information.
It seems like FreeBSD uses the RTC such that it reflects the TZ time, and not UTC. So, the virtual machine has to be configured equally, with:
This needs to be run as root.
Confirm with:
It will give you this warning, but I found no other way to synchronize the times correctly.
Adrian
 root@debian:~# timedatectl set-local-rtc trueThis needs to be run as root.
Confirm with:
 timedatectlCode:
root@debian:~# timedatectl Local time: So 2017-06-25 16:29:57 CEST Universal time: So 2017-06-25 14:29:57 UTC RTC time: So 2017-06-25 16:29:56 Time zone: Europe/Berlin (CEST, +0200) Network time on: yes NTP synchronized: no RTC in local TZ: yes Warning: The system is configured to read the RTC time in the local time zone. This mode can not be fully supported. It will create various problems with time zone changes and daylight saving time adjustments. The RTC time is never updated, it relies on external facilities to maintain it. If at all possible, use RTC in UTC by calling 'timedatectl set-local-rtc 0'.
Adrian
