I got the following output from the nightly security run.
Can anyone give me some hints for troubleshooting (if any is warranted)
and/or let me know if this message is likely an indication of a pending
serious hardware problem/failure?
Based on the timing I suspect it was caused when my nightly CRON job ran
I saw a similar message on June 21
Both errors occurred at 3:01AM (the cron job is scheduled for 3:00).
I am running the following version of FreeNAS
Thanks in advance for any input.
freenas.YFG security run output Checking for uids of 0: root 0 Checking for passwordless accounts: Checking login.conf permissions: Checking for ports with mismatched checksums: freenas.YFG kernel log messages: +++ /tmp/security.yhiiKxAq 2012-09-10 03:01:01.000000000 -0400 +ahcich2: Timeout on slot 17 port 0 +ahcich2: is 00000000 cs 00020000 ss 00000000 rs 00020000 tfd c0 serr 00000000 freenas.YFG login failures: freenas.YFG refused connections: -- End of security output --
#! /bin/bash
savepath='/mnt/TANK/.diskdiag/' # Save Path for Files including trailing /
dt=`date "+%Y%m%d_%H%M%S"` # Date/Time is tempfile name / Base of final file name
for i in $(sysctl -n kern.disks | awk '{for (i=NF; i!=0 ; i--) if (match($i, '/ada/')) print $i }')
do
fn=$savepath$dt$id # Temp file for smartctl output
smartctl -a /dev/$i >$fn
nfn=`awk '/Device Model/{DevModel=$3;} /Serial Number/{SerNum=$3}; /Firmware Version/{FWVer=$3} END { print "~" DevModel "~" SerNum "~" FWVer; }' <$fn`
nfn="$fn~$i$nfn" # Make new name including device/model/serial/firmware version
mv $fn $nfn
done
Subject: freenas.YFG security run output Checking for uids of 0: root 0 Checking for passwordless accounts: Checking login.conf permissions: Checking for ports with mismatched checksums: freenas.YFG kernel log messages: +++ /tmp/security.p0UpeBca 2012-06-21 03:01:01.000000000 -0400 +ahcich2: Timeout on slot 1 port 0 +ahcich2: is 00000000 cs 00000002 ss 00000000 rs 00000002 tfd c0 serr 00000= 000 freenas.YFG login failures: freenas.YFG refused connections: -- End of security output --
FreeNAS Build FreeNAS-8.0.4-RELEASE-p2-x64 (11367) Platform Intel(R) Pentium(R) CPU G620 @ 2.60GHz Memory 16281MB OS Version FreeBSD 8.2-RELEASE-p7
