Specs:
FreeNAS 8.0.2
RAIDZ2 + 4K
Mobo: ASUS M4A88T-M LE (NB: AMD 880G, SB: AMD SB710)
CPU: AMD Athlon II X4 640
RAM: Kingston 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) ECC Unbuffered Server Memory
HDD: 4x SAMSUNG EcoGreen 1TB
I can duplicate the errors every time I try to copy a 16GB directory over from the old server to the new server.
About 10 minutes into it, I start getting "ahcichX: Timeout on slot NN port 0" where X ranges from 0-3 for all four disks. The list of related errors just keeps going.
I get the error no matter if SATA is configured for IDE or AHCI in the BIOS.
The system runs fine and can run for 24+ hours as long as I am not copying large amounts of data to it.
If I was getting errors on ONE drive I would believe it and replace it but getting errors on ALL FOUR when everything seems to be running fine?
I guess it could be the SATA controller?
I am not sure what to do now. I had been using FN7 for like 2+ years and NEVER had an issue with it, albeit on older hardware running a simply RAID1 configuration. Do I downgrade to FN7? Abandon FN altogether? Buy a PCI SATA controller card?
FreeNAS 8.0.2
RAIDZ2 + 4K
