Yes, I have a backup with rsync to my linux server.
Here are my SMART results:
HD1
[root@freenas ~]# smartctl -a /dev/ada0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCC4EDYVY00K
LU WWN Device Id: 5 0014ee 25ff16fe1
Firmware Version: 80.00A80
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon Aug 13 17:55:25 2018 CEST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (50880) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 509) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 202 176 021 Pre-fail Always - 6900
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 711
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 055 055 000 Old_age Always - 33556
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 81
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 41
193 Load_Cycle_Count 0x0032 197 197 000 Old_age Always - 11841
194 Temperature_Celsius 0x0022 114 107 000 Old_age Always - 38
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 33555 -
# 2 Short offline Completed without error 00% 33499 -
# 3 Extended offline Completed without error 00% 33265 -
# 4 Short offline Completed without error 00% 33254 -
# 5 Short offline Completed without error 00% 33230 -
# 6 Short offline Completed without error 00% 32991 -
# 7 Short offline Completed without error 00% 32751 -
# 8 Short offline Completed without error 00% 32543 -
# 9 Extended offline Completed without error 00% 32286 -
#10 Short offline Completed without error 00% 32275 -
#11 Short offline Completed without error 00% 32253 -
#12 Short offline Completed without error 00% 32012 -
#13 Short offline Completed without error 00% 31772 -
#14 Extended offline Interrupted (host reset) 70% 31536 -
#15 Short offline Completed without error 00% 31532 -
#16 Short offline Completed without error 00% 31292 -
#17 Short offline Completed without error 00% 31053 -
#18 Extended offline Completed without error 00% 30824 -
#19 Short offline Completed without error 00% 30813 -
#20 Short offline Completed without error 00% 30789 -
#21 Short offline Completed without error 00% 30550 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
HD2
[root@freenas ~]# smartctl -a /dev/ada1
Serial Number: WD-WCC4ER84E2KP
LU WWN Device Id: 5 0014ee 20a9c1bda
Local Time is: Mon Aug 13 17:57:31 2018 CEST
was never started.
been run.
data collection: (52080) seconds.
command.
power-saving mode.
recommended polling time: ( 521) minutes.
3 Spin_Up_Time 0x0027 205 180 021 Pre-fail Always - 6741
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 713
9 Power_On_Hours 0x0032 055 055 000 Old_age Always - 33555
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 82
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 42
193 Load_Cycle_Count 0x0032 197 197 000 Old_age Always - 11817
No Errors Logged
# 1 Short offline Completed without error 00% 33554 -
# 6 Short offline Completed without error 00% 32990 -
# 7 Short offline Completed without error 00% 32750 -
# 8 Short offline Completed without error 00% 32542 -
#11 Short offline Completed without error 00% 32252 -
#12 Short offline Completed without error 00% 32011 -
#13 Short offline Completed without error 00% 31771 -
#14 Extended offline Completed without error 00% 31543 -
#15 Short offline Completed without error 00% 31531 -
#17 Short offline Completed without error 00% 31052 -
#18 Extended offline Completed without error 00% 30823 -
#19 Short offline Completed without error 00% 30812 -
#20 Short offline Completed without error 00% 30788 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
HD3
[root@freenas ~]# smartctl -a /dev/ada2
Serial Number: WD-WCC4E48Y5930
LU WWN Device Id: 5 0014ee 20a9c22ca
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Aug 13 17:58:01 2018 CEST
was never started.
been run.
data collection: (52020) seconds.
command.
power-saving mode.
recommended polling time: ( 520) minutes.
3 Spin_Up_Time 0x0027 205 178 021 Pre-fail Always - 6750
193 Load_Cycle_Count 0x0032 197 197 000 Old_age Always - 11804
194 Temperature_Celsius 0x0022 109 102 000 Old_age Always - 43
No Errors Logged
# 2 Short offline Completed without error 00% 33498 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
HD4
[root@freenas ~]# smartctl -a /dev/ada3
Serial Number: WD-WCC4EF87VY7J
LU WWN Device Id: 5 0014ee 20a9c2f9c
Local Time is: Mon Aug 13 17:58:43 2018 CEST
was never started.
been run.
data collection: (51720) seconds.
command.
power-saving mode.
recommended polling time: ( 517) minutes.
3 Spin_Up_Time 0x0027 203 177 021 Pre-fail Always - 6850
9 Power_On_Hours 0x0032 055 055 000 Old_age Always - 33557
193 Load_Cycle_Count 0x0032 197 197 000 Old_age Always - 11832
No Errors Logged
# 1 Short offline Completed without error 00% 33556 -
# 2 Short offline Completed without error 00% 33500 -
# 3 Extended offline Completed without error 00% 33266 -
# 4 Short offline Completed without error 00% 33255 -
# 5 Short offline Completed without error 00% 33231 -
# 8 Short offline Completed without error 00% 32544 -
# 9 Extended offline Completed without error 00% 32287 -
#10 Short offline Completed without error 00% 32276 -
#12 Short offline Completed without error 00% 32013 -
#14 Extended offline Completed without error 00% 31544 -
#15 Short offline Completed without error 00% 31533 -
#16 Short offline Completed without error 00% 31293 -
#19 Short offline Completed without error 00% 30814 -
#21 Short offline Completed without error 00% 30551 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Thank you for your analyse.
Regards
