The swap partition has a label
marcosw
I have a TrueNAS-12.0-U5.1 system with 17 drives. 12 of the drives are in a RAIDZ2 pool and one is a boot drive. The others I used for experimenting and as spares.
When I run gpool status most drives show exactly one partition, but some show two and I don't understand why. For example:
                                      Name  Status  Components
gptid/e8405e1f-4150-11ea-9a62-001a6b51e736     N/A  da0p1
gptid/e9d4b812-4150-11ea-9a62-001a6b51e736     N/A  da0p2
gptid/f9584dbe-4150-11ea-9a62-001a6b51e736     N/A  da1p2
gptid/193abb34-4151-11ea-9a62-001a6b51e736     N/A  da2p2
gptid/ff5ce719-8090-11e9-9a5e-001a6b51e736     N/A  da3p1
gptid/162c130b-bcb8-11ea-8d04-001a6b51e736     N/A  da4p2
gptid/8c0f3bc9-2131-11ec-b384-001a6b51e736     N/A  da5p1
gptid/8c2b36d0-2131-11ec-b384-001a6b51e736     N/A  da5p2
gptid/1ca64966-4f8f-11ea-adea-001a6b51e736     N/A  da6p2
gptid/1e42c9da-4ae2-11ea-a5dc-001a6b51e736     N/A  da7p2
gptid/2c71ee85-1e8a-11ec-a91d-001a6b51e736     N/A  da8p2
gptid/43aa14d2-4151-11ea-9a62-001a6b51e736     N/A  da9p2
gptid/4cf6320d-4151-11ea-9a62-001a6b51e736     N/A  da10p2
gptid/d114f4e9-4973-11eb-80b3-001a6b51e736     N/A  da11p2
gptid/4b7e8089-1e77-11ec-9077-001a6b51e736     N/A  da12p2
gptid/4911aaa9-77b9-11eb-a388-001a6b51e736     N/A  da13p2
gptid/d495ff47-52cf-11ea-8d94-001a6b51e736     N/A  da14p2
gptid/082b7a58-1ef8-11ea-ba1e-001a6b51e736     N/A  da15p1
gptid/0837fc0e-1ef8-11ea-ba1e-001a6b51e736     N/A  da15p2
gptid/03ccfcdb-1ef8-11ea-ba1e-001a6b51e736     N/A  da16p1
gptid/03dc8e32-1ef8-11ea-ba1e-001a6b51e736     N/A  da16p2
In this caes da4 and da5 are both part of the 12 drive RAIDZ2 pool and their partitioning scheme is the same, yet da5p1 and da5p2 are both listed but only da4p2 is:
gpart show da5
=>        40  7814037088  da5  GPT  (3.6T)
          40          88       - free -  (44K)
         128     4194304    1  freebsd-swap  (2.0G)
     4194432  7809842696    2  freebsd-zfs  (3.6T)
 gpart show da4
=>        40  7814037088  da4  GPT  (3.6T)
da3 is the boot drive, so I'm not surprised that it's glabel status output is different, but da0, da5, da15, and da16 where added to the system using the GUI in the same way that all the other drives were, so there isn't any reason that their swap partition should show up in the gpool status output.
The output from gpart list for is nearly identical as well (though there are differences in the stripesize, stripeoffset, and mode):
Geom name: da4
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 7814037127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: da4p1
   Mediasize: 2147483648 (2.0G)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   efimedia: HD(1,GPT,166f3ac6-bcb8-11ea-8d03-001a6b51e736,0x80,0x400000)
   rawuuid: 166f3ac6-bcb8-11ea-8d03-001a6b51e736
   rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: da4p2
   Mediasize: 3998639460352 (3.6T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   efimedia: HD(2,GPT,162c130b-bcb8-11ea-8d04-001a6b51e736,0x400080,0x1d180be08)
   rawuuid: 162c130b-bcb8-11ea-8d04-001a6b51e736
   rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 3998639460352
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 7814037127
   start: 4194432
Consumers:
1. Name: da4
   Mediasize: 4000787030016 (3.6T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: da5
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 7814037127
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: da5p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r0w0e0
   efimedia: HD(1,GPT,8c0f3bc9-2131-11ec-b384-001a6b51e736,0x80,0x400000)
   rawuuid: 8c0f3bc9-2131-11ec-b384-001a6b51e736
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: da5p2
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 2147549184
   Mode: r1w1e2
   efimedia: HD(2,GPT,8c2b36d0-2131-11ec-b384-001a6b51e736,0x400080,0x1d180be08)
   rawuuid: 8c2b36d0-2131-11ec-b384-001a6b51e736
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 7814037127
   start: 4194432
Consumers:
1. Name: da5
   Sectorsize: 512
   Mode: r1w1e3
One thing that I can think of is that the drives which show multiple partitions in the glabel status output were added to system as replacements when a different version of FreeNAS was being used and so were initialized with unusual settings, however since gpart list shows uuids for both partitions I'm not sure that make sense.
Thanks.
marcos
