My TrueNAS Scale server is on v22.12.3.3. I'm using the community Tailscale chart release.
Previously, the Tailscale chart would restart fine after a system reboot or app shutdown, but ever since the Tailscale update to v1.50.0_1.0.18, it fails to restart after anything shuts it down.
This is what the final lines of its log shows after it fails to boot up:
I'm wondering if this is an issue with the community chart or with Tailscale. The only thing I did was update the chart when the update was available.
Each time this happens, I have to go generate a new key for Tailscale to work.
Thanks for your time.
2023/10/01 16:25:44 control: Generating a new nodekey.
2023/10/01 16:25:44 control: RegisterReq: onode= node=[+IvsT] fup=false nks=false
2023/10/01 16:25:45 control: RegisterReq: got response; nodeKeyExpired=false, machineAuthorized=false; authURL=false
2023/10/01 16:25:45 Received error: invalid key: API key <API KEY REDACTED> not valid
backend error: invalid key: API key <API KEY REDACTED> not valid
boot: 2023/10/01 16:25:45 failed to auth tailscale: failed to auth tailscale: tailscale login failed: exit status 1
