system x3650 M4
porcomaster
Good morning guys , i am installing CentOS 7 to a system x3650 M4 128 GB of ram , and 8 TB of space , i am doing that because freenas have problem with a hardware RAID , anyway , i would love to use freenas anyway , so i would like to know if this task is impossible , if so , i will keep on CentOS 7 , thanks in advance for any response .
porcomaster
You'll need a IBM M1015 cross flashed to IT mode in order to use an X3650 with FreeNAS.
Thank you , for your fast response , i will keep on CentOS 7 , them :/... IBM M1015 is 500 dolar's in brazil , and x3650 M4 uses a m5110e , that will not work without this piece , thank you again for your fast response , to bad i love freenas at home , and would love to use it in company
melloa
What other cards are available in the tropical land that you can get your hands on? Maybe there is one that the folks here would support using...
melloa
melloa
As long as you follow what's recommended, I'd say ZFS is a safe environment.
melloa
