.system runs out of space
Trevor68
I have a dataset that keeps chewing up space and I'm not sure what it is, or does? It's a folder called .system, and something called glustered in particular.
I have the system partition set to a different pool, so I have no idea why this is even there?
morganL
Captain Morgan
Administrator
Which version of SCALE software?
Glusterd is used for clustering for SMB.. unless enabled, it should not be active.
Trevor68
I have backed up to 12.2.2 until the PCI hotfix for 12.2.3. This space issue has been around for for a few versions though, I only figured out the cause this morning. Where/how can I check if clustering is active? Also why is that .system folder even there? I have it set to a different pool and was going to delete it until I worked out it is growing.
Trevor68
I did some digging and definitely not active.
