System/Reporting empty(freenas8)
robo
The Tab System/Reporting field is empty, no graphs are displaying. I couldn't figure out how to fix it. Has somebody a HowTo for it or a hint to fix this issue?
thanks for help!
C
clumpy
Guest
Hi Robo,
If it makes you feel better then I have the same issue. It was working on RC5 i386 but disappeared when I moved to the AMD64 version.
Clumpy
esamett
try clearing browser cache. dont use internet explorer
C
clumpy
Guest
Thanks for that guys, I use Firefox and Chrome both are the same. I tried the commands in the link but the find didn't come back with any results. Darn!
tigger490
Try this find command first:
find /var/db -name "*.rrd"
You should get several .rrd files returned. If not, I'm not sure what your next steps would be.
If you do have the .rrd files follow the instructions in the link again, but use this find command instead of the one there. The one in the link was missing the quotes:
find /var/db -name "*.rrd" -exec rm -rf {} \;
D-Joe
Hi guys,
i've got the same problem. In System/Reporting the only graph which is shown is the "Diskspace"-graph all other graphs are emty.
I tried the tips above but nothing happened.
I'am running FreeNas 8 Release on a ASUS E35M1-I.
EDIT: I just updated to FreeNAS-8.0.1-BETA2-amd64 and all report graphs are no shown correctly
FreeNAS 8.3.0
Manually create the missing dir:
1. Open "Shell".
2. Type:
mkdir /var/db/collectd/rrd/localhost/df <press enter>
mkdir /var/db/collectd/rrd/localhost/interface <press enter>
3. Close Shell.
