Thinkcat
- Aug 3, 2015
Hello
I am building a small NAS that I will administer but probably not use. It has now three 4TB WD Red disks, intended to be used as a RAID-1 three way mirror. I have a Fractal Design Node 304 case with Corsair RM550x power supply. There is room for a second set of three disks.
My motherboard options are either Supermicro X10SDV-2C-TLN2F (D-1508, 2 cores, 2 x 10 gbit), X10SDV-4C-TLN4F (D-1518, 4 cores, 2 x 10 gbit, 2 x 1 gbit) or X10SDV-4C-TLN2F (D-1520/1521, 4 cores, 2 x 10 gbit). I see that all these have an M.2 slot that I hope to use for a boot drive. I also assume that if I buy a PCI-E based M.2 drive, it will not conflict with any SATA functionality.
The case only allows for Mini-ITX, and there is no general purpose Xeon motherboard for that size, so I assume I will go with Xeon D. Unless someone can suggest something better. Someone more budget conscious would probably want such a motherboard and a Haswell or Skylake i3.
Or what would I basically lose if I got an Avoton motherboard? Say, A1SAi-2550F? I'd lose the M.2 socket, yes. The 10 gbit LAN is not strictly necessary. Four of the SATA ports would be SATA2 and only two would be SATA3. I would have an internal USB 3 header for the system disk, maybe an SSD with some SATA to USB adapter.
1) Can FreeNAS boot out of an M.2 drive? Does it matter if it is a SATA or PCI-E based one?
2) Is there any problem I could encounter with a Xeon D generally?
3) Can I use all 6 SATA connectors with the M.2 if I buy a PCI-E M.2 drive?
4) I think I saw that the support for the 10 gbit Ethernet is now working. Correct?
5) I need some memory that is easily available in Europe. Any suggestions? I do not plan to go for full density or maximum size. Maybe begin with 16 GB and then expand if necessary.
6) Is the D-1508 missing anything? It is, after all, called Pentium, whereas the others are Xeon.
