I recently built a NAS with super micros motherboard X10SL7-F. Chassi is Fractal design define r4. that is qite big.
The problem I encountered is that fans either at full speed or hopping rate (4 sec at 300-400 RPM, then at full speed for 4 sec............).
This can not be set anywhere on the motherboard / IPMI / BIOS. I cant find any inteligent fan control for low noise chassi fans in size as mine.
In IPMI, I see that the motherboard detects low speed fans that I have inserted and get warning at 347 rpm.
I can set the max speed in IPMI but then fans goes at full speed and it sounds pretty much from my 4pcs -140 mm fans. It feels like the NAS soon will fly away
Temperature of the CPU is cool (<40C). Disks are not activated.
I got an answer from support that there are third-party IPMIUTIL where users can change it, even fan speeds and thresholds. Then I found online that there are also FREEIPMI that is similar to ipmiutil.
Is there anyone who has used IPMIUTIL or freeipmi?
Please tell me how it worked and how to install it in freenas/ on supermicro board.
Thank you!
Thank you!
