Sun 10GBe Dual Port PCI-E Ethernet Adapter 375-3617-01
rmetola
Hi Guys,
Do any of you know if these adapters are supported by freenas?
It seems they use intel chipset Intel 82599EB 10 Gigabit Ethernet controller.
Do you know if it supported?
thanks for your time!
R
bigphil
It should work with the ix driver as that is the same chipset that the Intel X520 cards use. Try it out and let us know.
rmetola
Hi bigphil,
Thanks for your comment, as soon as i can i will try and let u guys know.
Regards,
