I have a ZFS pool setup on my server at /mnt/media. It's owned by a user I created (say "foo" for discussion) and setup as an AFP share. Default file/direction permissions are that everyone has read & owner/group have w+x. On my Mac (10.13.2), I login to the share as the user I created. Everything's been fine for a long time.
Recently, I had a drive go bad, replaced it, and everything rebuilt fine. I then used Lightroom to import some images to a folder on it, and everything was fine.
However, I wanted to make a new folder at the root level of the share. When I tried to do it in the Finder, Finder pulls up an authentication box and says it wants permission to make the folder. I tried giving it admin to my Mac and using the various logins for my FreeNAS box, but it'd never authenticate to create the folder. I was able to make it using the terminal on my FreeNAS box. Then, when I tried to copy a few files to the folder, one copied just fine but another again started insisting on needing permission to copy over.
I used Disk Utility to check that my local permissions was OK, and everything was fine.
Does anyone have any clue why this suddenly started happening and thoughts on how to fix it? I couldn't find anything in the archives here. Thanks!
