Stuck in Reboot Loop
rhunton
Evening, I'm after some help please.
I decided I needed to upgrade my NAS at the weekend to 9.10 from a pre 9.3
I logged into the NAS and completed the firmware upgrade to v9.3 and this completed fine.
I then upgraded my ZFS pool using the GUI and decided I may as well upgrade to 9.10 while feeling confident.
I changed the train to 9.10 and applied all the updates but now when the server is booting I keep getting a message of:
Generating grub configuration file...
done
Shutdown NOW!
shutdown: [pid 8887]
System shutdown time has arrived.
The server reboots and then just repeats again..
I can get into my FreeNAS but need to be in front of it and send a CTRL+C to stop it generating the Grub config file.
Anyone know how I can resolve this?
Thanks in advance.
Rob
In the GRUB menu, choose an older boot environment, then try the update again. Today's update might help.
Alex.G
I'm having the exact same issue. After 'Generating GRUB configuration file' the system just reboots straight away and gets stuck in this reboot loop.
This was after performing a system update to the very latest 9.10.1-U2 just 2 days ago.
Then file bug reports.
Guille
Hi, have anyone resolved this? It happens to me intermitently. I have to reboot it several times in order to keep it running. When it runs, everything is fine.
Thanks
rhunton
Hi Guille,
I found my issue was down to ram not getting detected.
The server would reboot but only with 8gb of 16gb, it would then generate a grub configuration file and reboot, on reboot it would find 16gb and again build a grub config and reboot again and lose 8gb and it would go around in circles like that.
I found hitting ctrl + c when it got to generating the file got me into the server.
In the end i moved my ram over into a HP N54L server from the N40L I was running and touch wood never had an issue since.
Hope that's of some use.
Rob
Guille
Thank you Rob.
It may have something to do with memory. This problem started when I switched a memory module (2GB to 4GB).
Now it seems to be stable.
Won't fiddle with it much more than this. Waiting for 10.0...
