Hostname.........: RVDPA-VEEAMNAS02.mittalco.com
Build................: FreeNAS-8.2.0-RELEASE-p1-x64 (r11950)
Platform...........: Intel(R) Core(TM)2 CPU E8400 @ 3.00GHz
Memory...........: 963MB
System Time....: Mon Nov 19 08:46:05 CST 2012
Uptime............: 8:46AM up 11:11, 0 users
Load Average...: 0.08, 0.04, 0.01
On this system at first I tried zfs, but obviously it had insuffient RAM, so I created two ufs RAID 1 volumes and used CIFS to share them. These volumes are target storage for backing up my VMware files using Veeam Backup. Installed in the desktop computer are four 2TB SATA drives.
All was working fine but I had heard iSCSI was better than CIFS so I decided to give iSCSI a try. I deleted the CIFS share for RAID 1 volume with ada2 and ada3 with a destroy. I added them as Device Extents (extent2 and extent3) and targets (iSCSI2 and iSCSI3). This worked fine, but I wanted RAID protection so decided to try instead using a file based extent to a ufs RAID 1 volume (path "/mnt/VeeamBackup/data" size 1600GB). After removing the extents and targets it left these two disks unusable. I can't create any kind of volume, import or even set them back as an iSCSI device extent. Now the weird thing is I then did the same with ada0 and ada1 and it worked without a problem.
When I tried to create the volume iSCSI1 as ufs RAID 1 it failed, but now when I try auto import volume it see iSCSI1(geom). I assume removing this from the list may be the ticket to success, but can' figure out how. It appears during the reboot an attempt is even made to mount iSCSI1 volume, but below in the log you can see this and all my attempts at wiping the disk, auto imports, etc.
LOG:
Nov 18 21:36:01 RVDPA-VEEAMNAS02 newsyslog[1305]: logfile first created
Nov 18 21:36:01 RVDPA-VEEAMNAS02 syslogd: kernel boot file is /boot/kernel/kernel
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: Copyright (c) 1992-2011 The FreeBSD Project.
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: The Regents of the University of California. All rights reserved.
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: FreeBSD 8.2-RELEASE-p9 #0: Thu Jul 19 12:39:10 PDT 2012
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: root@build.ixsystems.com:/build/home/jpaetzel/8.2.0/os-base/amd64/build/home/jpaetzel/8.2.0/FreeBSD/src/sys/FREENAS.amd64 amd64
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: CPU: Intel(R) Core(TM)2 CPU E8400 @ 3.00GHz (3001.46-MHz K8-class CPU)
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: Origin = "GenuineIntel" Id = 0x1067a Family = 6 Model = 17 Stepping = 10
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada0 at ahcich0 bus 0 scbus4 target 0 lun 0
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada0: ATA-8 SATA 2.x deviceda0 at umass-sim0 bus 0 scbus10 target 0 lun 0
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: da0: Removable Direct Access SCSI-0 device
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: da0: 40.000MB/s transfers
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: da0: 3864MB (7913472 512 byte sectors: 255H 63S/T 492C)
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada0: Command Queueing enabled
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada1 at ahcich1 bus 0 scbus5 target 0 lun 0
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada1: ATA-8 SATA 2.x device
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada1: Command Queueing enabled
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada2 at ahcich2 bus 0 scbus6 target 0 lun 0
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada2: ATA-8 SATA 2.x device
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada2: Command Queueing enabled
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada3 at ahcich4 bus 0 scbus8 target 0 lun 0
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada3: ATA-8 SATA 2.x device
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada3: Command Queueing enabled
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: ada3: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: SMP: AP CPU #1 Launched!
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: GEOM_MIRROR: Device mirror/iSCSI0 launched (2/2).
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: GEOM_MIRROR: Device mirror/iSCSI1 launched (2/2).
Nov 18 21:36:01 RVDPA-VEEAMNAS02 kernel: Trying to mount root from ufs:/dev/ufs/FreeNASs1a
Nov 18 21:36:01 RVDPA-VEEAMNAS02 root: /etc/rc: WARNING: Dump device does not exist. Savecore not run.
Nov 18 21:36:01 RVDPA-VEEAMNAS02 ntpd[1471]: ntpd 4.2.4p5-a (1)
Nov 18 21:36:01 RVDPA-VEEAMNAS02 root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Nov 18 21:36:13 RVDPA-VEEAMNAS02 kernel: ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present;
Nov 18 21:36:13 RVDPA-VEEAMNAS02 kernel: to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
Nov 18 21:36:13 RVDPA-VEEAMNAS02 kernel: ZFS filesystem version 4
Nov 18 21:36:13 RVDPA-VEEAMNAS02 kernel: ZFS storage pool version 15
Nov 18 21:39:19 RVDPA-VEEAMNAS02 ntpd[1472]: time reset +1.137946 s
Nov 18 21:40:17 RVDPA-VEEAMNAS02 notifier: dd: /dev/ada2: Operation not permitted
Nov 18 21:40:17 RVDPA-VEEAMNAS02 notifier: dd: /dev/ada3: Operation not permitted
Nov 18 21:40:17 RVDPA-VEEAMNAS02 notifier: geom: Command 'load' not available.
Nov 18 21:40:17 RVDPA-VEEAMNAS02 manage.py: [middleware.exceptions:38] [MiddlewareError: Volume creation failed: "geom: Can't store metadata on /dev/ada2: Operation not permitted., "]
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: istgt not running? (check /var/run/istgt.pid).
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: Starting istgt.
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: istgt version 0.4 (20111008)
Nov 18 21:42:17 RVDPA-VEEAMNAS02 istgt[3128]: istgt version 0.4 (20111008)
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: normal mode
Nov 18 21:42:17 RVDPA-VEEAMNAS02 istgt[3128]: normal mode
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: istgt_lu.c: 911:istgt_lu_check_iscsi_name: ***ERROR*** invalid iqn format. expect "iqn.YYYY-MM.reversed.domain.name"
Nov 18 21:42:17 RVDPA-VEEAMNAS02 istgt[3128]: istgt_lu.c: 911:istgt_lu_check_iscsi_name: ***ERROR*** invalid iqn format. expect "iqn.YYYY-MM.reversed.domain.name"
Nov 18 21:42:17 RVDPA-VEEAMNAS02 istgt[3128]: istgt_lu.c:1287:istgt_lu_add_unit: ***ERROR*** TargetName iqn.RVDPA-VEEAMNAS02.istgt:iscsi0 contains an invalid character or format.
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: istgt_lu.c:1287:istgt_lu_add_unit: ***ERROR*** TargetName iqn.RVDPA-VEEAMNAS02.istgt:iscsi0 contains an invalid character or format.
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: LU3 HDD UNIT
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: LU3: LUN0 file=/mnt/iSCSI0/VeeamBackup/data, size=1717986918400
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: LU3: LUN0 3355443200 blocks, 512 bytes/block
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: LU3: LUN0 1600.0GB storage for iqn.RVDPA-VEEAMNAS02.istgt:iscsi0
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: LU3: LUN0 serial 001cc008074c020
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: LU3: LUN0 read cache enabled, write cache enabled
Nov 18 21:42:17 RVDPA-VEEAMNAS02 notifier: LU3: LUN0 command queuing enabled, depth 32
Nov 18 21:42:18 RVDPA-VEEAMNAS02 istgt[3129]: Login from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on iqn.rvdpa-veeamnas02.istgt:iscsi0 LU3 (10.130.151.132:3260,1), ISID=400001370000, TSIH=1, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 21:43:33 RVDPA-VEEAMNAS02 notifier: gpart: geom '/dev/ada3': Invalid argument
Nov 18 21:43:33 RVDPA-VEEAMNAS02 notifier: gpart: geom 'ada3': Operation not permitted
Nov 18 21:43:33 RVDPA-VEEAMNAS02 manage.py: [middleware.exceptions:38] [MiddlewareError: Failed to wipe ada3: dd: /dev/ada3: Operation not permitted ]
Nov 18 21:43:46 RVDPA-VEEAMNAS02 notifier: gpart: geom '/dev/ada2': Invalid argument
Nov 18 21:43:46 RVDPA-VEEAMNAS02 notifier: gpart: geom 'ada2': Operation not permitted
Nov 18 21:43:46 RVDPA-VEEAMNAS02 manage.py: [middleware.exceptions:38] [MiddlewareError: Failed to wipe ada2: dd: /dev/ada2: Operation not permitted ]
Nov 18 21:45:47 RVDPA-VEEAMNAS02 istgt[3129]: istgt_lu.c: 465:istgt_lu_find_target: ***WARNING*** can't find target iqn.rvdpa-veeamnas02.istgt:iscsi2
Nov 18 21:45:47 RVDPA-VEEAMNAS02 istgt[3129]: istgt_iscsi.c:2088:istgt_iscsi_op_login: ***ERROR*** lu_find_target() failed
Nov 18 21:45:48 RVDPA-VEEAMNAS02 istgt[3129]: istgt_lu.c: 465:istgt_lu_find_target: ***WARNING*** can't find target iqn.rvdpa-veeamnas02.istgt:iscsi3
Nov 18 21:45:48 RVDPA-VEEAMNAS02 istgt[3129]: istgt_iscsi.c:2088:istgt_iscsi_op_login: ***ERROR*** lu_find_target() failed
Nov 18 21:45:48 RVDPA-VEEAMNAS02 istgt[3129]: Login from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on iqn.rvdpa-veeamnas02.istgt:iscsi0 LU3 (10.130.151.132:3260,1), ISID=400001370001, TSIH=2, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 21:45:50 RVDPA-VEEAMNAS02 istgt[3129]: Login(discovery) from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on (10.130.151.132:3260,1), ISID=400001370000, TSIH=1, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 21:45:50 RVDPA-VEEAMNAS02 istgt[3129]: Logout(discovery) from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on (10.130.151.132:3260,1), ISID=400001370000, TSIH=1, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 21:51:01 RVDPA-VEEAMNAS02 notifier: dd: /dev/ada2: Operation not permitted
Nov 18 21:51:01 RVDPA-VEEAMNAS02 notifier: dd: /dev/ada3: Operation not permitted
Nov 18 21:51:01 RVDPA-VEEAMNAS02 notifier: geom: Command 'load' not available.
Nov 18 21:51:01 RVDPA-VEEAMNAS02 manage.py: [middleware.exceptions:38] [MiddlewareError: Volume creation failed: "geom: Can't store metadata on /dev/ada2: Operation not permitted., "]
Nov 18 21:54:33 RVDPA-VEEAMNAS02 istgt[3129]: Login(discovery) from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on (10.130.151.132:3260,1), ISID=400001370000, TSIH=2, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 21:54:33 RVDPA-VEEAMNAS02 istgt[3129]: Logout(discovery) from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on (10.130.151.132:3260,1), ISID=400001370000, TSIH=2, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 21:54:50 RVDPA-VEEAMNAS02 ntpd[1472]: kernel time sync status change 2001
Nov 18 21:59:28 RVDPA-VEEAMNAS02 istgt[3129]: Login(discovery) from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on (10.130.151.132:3260,1), ISID=400001370000, TSIH=3, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 21:59:28 RVDPA-VEEAMNAS02 istgt[3129]: Logout(discovery) from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on (10.130.151.132:3260,1), ISID=400001370000, TSIH=3, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 21:59:31 RVDPA-VEEAMNAS02 istgt[3129]: Login(discovery) from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on (10.130.151.132:3260,1), ISID=400001370000, TSIH=4, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 21:59:31 RVDPA-VEEAMNAS02 istgt[3129]: Logout(discovery) from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on (10.130.151.132:3260,1), ISID=400001370000, TSIH=4, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 22:08:15 RVDPA-VEEAMNAS02 istgt[3129]: Login(discovery) from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on (10.130.151.132:3260,1), ISID=400001370000, TSIH=5, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 22:08:15 RVDPA-VEEAMNAS02 istgt[3129]: Logout(discovery) from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on (10.130.151.132:3260,1), ISID=400001370000, TSIH=5, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 22:08:22 RVDPA-VEEAMNAS02 istgt[3129]: Login(discovery) from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on (10.130.151.132:3260,1), ISID=400001370000, TSIH=6, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 22:08:22 RVDPA-VEEAMNAS02 istgt[3129]: Logout(discovery) from iqn.1991-05.com.microsoft:rvdpa-wsus.americas.mittalco.com (10.130.151.138) on (10.130.151.132:3260,1), ISID=400001370000, TSIH=6, CID=1, HeaderDigest=off, DataDigest=off
Nov 18 22:30:15 RVDPA-VEEAMNAS02 notifier: dd: /dev/ada2: Operation not permitted
Nov 18 22:30:15 RVDPA-VEEAMNAS02 notifier: dd: /dev/ada3: Operation not permitted
Nov 18 22:30:15 RVDPA-VEEAMNAS02 notifier: geom: Command 'load' not available.
Nov 18 22:30:15 RVDPA-VEEAMNAS02 manage.py: [middleware.exceptions:38] [MiddlewareError: Volume creation failed: "geom: Can't store metadata on /dev/ada2: Operation not permitted., "]
Nov 18 22:30:36 RVDPA-VEEAMNAS02 notifier: dd: /dev/ada2: Operation not permitted
Nov 18 22:30:36 RVDPA-VEEAMNAS02 manage.py: [middleware.exceptions:38] [MiddlewareError: Unable to GPT format the disk "ada2"]
Nov 18 22:30:55 RVDPA-VEEAMNAS02 notifier: dd: /dev/ada3: Operation not permitted
Nov 18 22:30:55 RVDPA-VEEAMNAS02 manage.py: [middleware.exceptions:38] [MiddlewareError: Unable to GPT format the disk "ada3"]
Nov 18 23:33:13 RVDPA-VEEAMNAS02 notifier: gpart: geom '/dev/ada3': Invalid argument
Nov 18 23:33:13 RVDPA-VEEAMNAS02 notifier: gpart: geom 'ada3': Operation not permitted
Nov 18 23:33:13 RVDPA-VEEAMNAS02 manage.py: [middleware.exceptions:38] [MiddlewareError: Failed to wipe ada3: dd: /dev/ada3: Operation not permitted ]
Nov 18 23:36:01 RVDPA-VEEAMNAS02 notifier: dd: /dev/ada2: Operation not permitted
Nov 18 23:36:01 RVDPA-VEEAMNAS02 notifier: dd: /dev/ada3: Operation not permitted
Nov 18 23:36:01 RVDPA-VEEAMNAS02 notifier: geom: Command 'load' not available.
Nov 18 23:36:01 RVDPA-VEEAMNAS02 manage.py: [middleware.exceptions:38] [MiddlewareError: Volume creation failed: "geom: Can't store metadata on /dev/ada2: Operation not permitted., "]
Nov 19 00:04:30 RVDPA-VEEAMNAS02 notifier: gpart: geom '/dev/ada2': Invalid argument
Nov 19 00:04:30 RVDPA-VEEAMNAS02 notifier: gpart: geom 'ada2': Operation not permitted
Nov 19 00:04:30 RVDPA-VEEAMNAS02 manage.py: [middleware.exceptions:38] [MiddlewareError: Failed to wipe ada2: dd: /dev/ada2: Operation not permitted ]
Nov 19 00:04:31 RVDPA-VEEAMNAS02 manage.py: [storage.views:985] Could not check for disk wipe progress: [Errno 3] No such process
Nov 19 00:04:33 RVDPA-VEEAMNAS02 last message repeated 2 times
Nov 19 00:05:01 RVDPA-VEEAMNAS02 notifier: gpart: geom '/dev/ada3': Invalid argument
Nov 19 00:05:01 RVDPA-VEEAMNAS02 notifier: gpart: geom 'ada3': Operation not permitted
Nov 19 00:05:01 RVDPA-VEEAMNAS02 manage.py: [middleware.exceptions:38] [MiddlewareError: Failed to wipe ada3: dd: /dev/ada3: Operation not permitted ]
Nov 19 00:05:02 RVDPA-VEEAMNAS02 manage.py: [storage.views:985] Could not check for disk wipe progress: Nov 19 09:10:01 RVDPA-VEEAMNAS02 notifier: dd: /dev/ada2: Operation not permitted
Nov 19 09:10:01 RVDPA-VEEAMNAS02 notifier: dd: /dev/ada3: Operation not permitted
Nov 19 09:10:01 RVDPA-VEEAMNAS02 notifier: geom: Command 'load' not available.
Nov 19 09:10:01 RVDPA-VEEAMNAS02 manage.py: [middleware.exceptions:38] [MiddlewareError: Volume creation failed: "geom: Can't store metadata on /dev/ada2: Operation not permitted., "]
LOG:
