stuck at consle setup
Zaltsi
Hello i have tried to install freenas 9.10 , FreeNAS-11.1-U7 , FreeNAS-9.3 , FreeNAS-11.2-U5 and all of them just stuck in consle setup why can i do thanks all the answer
D
dlavigne
Guest
A screenshot of where you are stuck would be useful.
Also, per the Forum Rules, post your hardware specs.
Zaltsi
my pc spec is
i7 4790
gtx 1060
8 ram
120gb ssd
Zaltsi
i cant it stuck on the screen its like freeze i
press enter and nothing happen...
Why on Earth do you have a GTX 1060 in your server!?
Fredda
i can't it stuck on the screen its like freeze i
Have you read this thread?
Check if you keyboard is even working. Will pressing the caps-lock key light a LED on the keyboard? Try using another keyboard, PS/2 if available.
