m0nsieurPsych0
- Jul 11, 2021
Hi there!
I have been having this error at boot a couple of time over the years and I thought this error was caused from bad usb drives. Every time, I was able to resolve this issue by reinstalling Truenas/Freenas on another usb drive and restoring the config from backup. Lately, I have ditched the usb boot drives in favor of a mirror of two hdd, but again this error came back as of last night. In the last couple of days I had issues with one of my UPS that I have now replaced, but it did cause the system to unexpectedly shutdown a couple of times.
Now, I don't think this error is related to the status of the either the boot pool or the storage pools. When it get stuck at I am still able to press CTRL+C and skip that part and boot the rest of the way. Unfortunately, the system seems to not be loaded properly as I am not able to access either the web interface or the ssh connection. I am however to ping the server and to locally log in with root.
When I log in and I run everything seems to be OK, no error detected either from boot pool or my two other pool Atlantis and Stratos.
I checked the services and middlewared is running, sshd is running and nginx is running. I've tried restarting the services but still I cannot access remotely.
Also, the pool are mounted and I can access the file within them.
I have to add that the console is spammed by an system message pertaining to and I admit I am not sure if it's bad or not.
To be honest, I don't feel like re-configuring everything from scratch and re-importing the pool if there is an alternative solution available. Since I was not able to find much info about this issue on google or here, I am asking for your help.
Thank you!
PS: keep in mind, that I am not able to easily copy the error message/logs since I can only interact with the local console so here's some picture I took of the problem.
spa_history.c:296:spa_history_log_sync(): command: zpool set cachefile=/data/zfs/zpool.cache Stratos
zpool status
collectd 1738 - - plugin_dispatch_values: [...]
Thank you!
