Strange Errors on My Freenas Box
gabster
Hi All!
The past 3 days I am noticing a list of errors after a successful boot (see attached screenshot). Everything works fine (accessing and writing files, etc.).
Any idea what this could be?
Thanks!
Gabi
Spearfoot
He of the long foot
gabster
Thanks @Spearfoot - why unfortunate?
Is it something that I should be worried about and fix it? If yes, do you have a suggestion on where should I start?
thanks!
g
Spearfoot
He of the long foot
thanks!
g
'Unfortunate' in the sense that you're still experiencing a problem, whereas most FreeNAS users do not. This had to do with a new certificate installation recently, and maybe a DNS change? Anyway, I wouldn't worry about it unless iXsystems releases an update and you're still unable to reach the update server.
