Storage files are not updated!
HI!
I'm facing a curious problem, below is the current scenario:
2x Servers Server 2008 X64 Enterprise
1x Storage FreeNAS 9.1
On servers'm using the "iSCSI Initiator" to connect the Storage hitherto everything running smoothly. However I noticed that files created in storage are not displayed on both servers.
Ex: From Server 1 I created a TXT file in the Storage unit.
If I try to access the Storage Server 2, I will not see the file created by server 1. Only after restarting the Storage file is displayed for both servers.
Could someone help me?
PS.: Sorry for my bad english!
So if I understand you correctly, you are using iSCSI on 2 servers simultaneously, but one change isn't made to the other, correct?
Well, you can't share iSCSI devices with more than 1 device. That's the easiest way to corrupt your data. One iSCSI device should only be mounted on 1 machine. Any more than that and you risk corrupting data and your file system. Read up on clustering file systems for more info. ;)
