Being a total linux/freensd noob, I had no idea why my scripts were running on boot. they were throwing all kinds of errors. So I'm trying to post what I finally got to work here so others don't have to struggle for as long as I did...someone please correct me if I'm wrong
1. in your script file, make sure the VERY FIRST line of the script is
2. also in your script file, when you refer to a command (like smartctl or tmux or ipmitool), make sure to list its FULL path. ie:
replacing ipmitool with your command, keep the double quotes.
3. in order to run a script in tmux (so it can run I the background, not in your main shell), in the Freenas GUI, run a command NOT a script like:
in order to get back to that tmux session, goto shell and type:
*replace SESSION-NAME with your name of choice
*replace YOURPOOL with your pool name
*replace YOURscriptFOLDER with your path to the script
*replace script.sh with your script name
4. you may or may NOT? need to chmod your script file to be executable via:
hope this helps some other linux newbie...
#!/bin/bash #!/usr/bin/env bash
or whatever sell you intend to use. - I originally had some what I thought were commented out lines at the very top and it just threw constant errors EVEN THOUGH I was able to run it normally when logged in via SSH.2. also in your script file, when you refer to a command (like smartctl or tmux or ipmitool), make sure to list its FULL path. ie:
/usr/local/sbin/smartctl
OR /usr/local/bin/tmux
. tip: if you want to find which directory the command you want to use is, for example type: find . "ipmitool"
/usr/local/bin/tmux new-session -d -s SESSION-NAME /mnt/YOURPOOL/YOURscriptFOLDER/script.sh
tmux a -t SESSION-NAME
chmod +x /mnt/YOURPOOL/YOURscriptFOLDER/script.sh
