Starting Network fails, but only when booting the system
ClarkYoung
Can someone tell me how to debug this?
I can't get to the Web UI when I reboot the system. I am forced to choose option 1 and redefine the ipv4 address and gateway each time I boot.
Chris Moore
ClarkYoung
Chris Moore
You are correct. The problem is related to hardware. When I import one of my hard drives into a pool it somehow breaks the network when booting
I know that I am correct. That wasn't a question.
If you tell us what hardware you are using, we might be able to isolate the problem and suggest a correction.
ClarkYoung
OS Version:
FreeNAS-11.2-BETA3
(Build Date: Sep 10, 2018 1:18)
Processor:
Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz (4 cores)
Memory:
8 GiB
HostName:
DVR.local
The hard drive that is causing the failure is a Samsung model HD155UI
I will provide more detail later today when I get home ...
Chris Moore
A hard drive is causing networking problems?
Did you look at the forum rules I linked earlier?
The hardware you listed is not detailed at all and does not show the brand or model of the system board.
If you are not going to answer the most basic questions, nobody will be able to help you.
ClarkYoung
Sorry Chris, Did you see that I committed to providing more detail when I get home?
Chris Moore
