STABLE-201605240427 - Install problem
Borja Marcos
I've had a problem with this image, trying to install FreeNAS. I simply copied the image to a USB memory stick using dd. Booting the server with it, the installation failed after selecting the disks and entering the root password.
The error was:
No handlers could be found for logger "freenasOS.Configuration"
and a traceback.
Photo attached of the complete error message.
Installing with 9.10-STABLE and subsequent update to the latest STABLE today worked perfectly, though.
m0nkey_
Can you provide details of your FreeNAS hardware as per the forum rules? It'll help troubleshoot the issue.
Borja Marcos
Sorry. Hardware details follow.
I installed the RELEASE version without troubles, and the update went fine. But the installation with the -STABLE image failed.
The machine is NOT in production (actually I installed FreeNAS in order to see how it behaved with NVMEs, so I can do any tests you wish).
[root@freenas] ~# more /var/run/dmesg.boot
Copyright (c) 1992-2016 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 10.3-RELEASE-p3 #0 215c0d0(9.10-STABLE): Mon May 23 21:40:06 PDT 2016
    root@build.ixsystems.com:/tank/home/nightlies/build-freenas9/_BE/objs/tank/home/nightlies/build-freenas9/_BE/trueos/sys/FreeNAS.amd64 amd64
FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512
CPU: Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz (2400.05-MHz K8-class CPU)
  Origin="GenuineIntel"  Id=0x306f2  Family=0x6  Model=0x3f  Stepping=2
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x7ffefbff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,SDBG,FMA,CX16,xTPR,PDCM,PCID,DCA,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
  AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
  AMD Features2=0x21<LAHF,ABM>
  Structured Extended Features=0x37ab<FSGSBASE,TSCADJ,BMI1,AVX2,SMEP,BMI2,ERMS,INVPCID,PQM,NFPUSG>
  XSAVE Features=0x1<XSAVEOPT>
  VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID,VID,PostIntr
  TSC: P-state invariant, performance statistics
real memory  = 139586437120 (133120 MB)
avail memory = 133403795456 (127223 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <SUPERM SMCI--MB>
FreeBSD/SMP: Multiprocessor System Detected: 32 CPUs
FreeBSD/SMP: 2 package(s) x 8 core(s) x 2 SMT threads
cpu0 (BSP): APIC ID:  0
cpu1 (AP): APIC ID:  1
cpu2 (AP): APIC ID:  2
cpu3 (AP): APIC ID:  3
cpu4 (AP): APIC ID:  4
cpu5 (AP): APIC ID:  5
cpu6 (AP): APIC ID:  6
cpu7 (AP): APIC ID:  7
cpu8 (AP): APIC ID:  8
cpu9 (AP): APIC ID:  9
cpu10 (AP): APIC ID: 10
cpu11 (AP): APIC ID: 11
cpu12 (AP): APIC ID: 12
cpu13 (AP): APIC ID: 13
cpu14 (AP): APIC ID: 14
cpu15 (AP): APIC ID: 15
cpu16 (AP): APIC ID: 16
cpu17 (AP): APIC ID: 17
cpu18 (AP): APIC ID: 18
cpu19 (AP): APIC ID: 19
cpu20 (AP): APIC ID: 20
cpu21 (AP): APIC ID: 21
cpu22 (AP): APIC ID: 22
cpu23 (AP): APIC ID: 23
cpu24 (AP): APIC ID: 24
cpu25 (AP): APIC ID: 25
cpu26 (AP): APIC ID: 26
cpu27 (AP): APIC ID: 27
cpu28 (AP): APIC ID: 28
cpu29 (AP): APIC ID: 29
cpu30 (AP): APIC ID: 30
cpu31 (AP): APIC ID: 31
random: <Software, Yarrow> initialized
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 2.0> irqs 0-23 on motherboard
ioapic1 <Version 2.0> irqs 24-47 on motherboard
ioapic2 <Version 2.0> irqs 48-71 on motherboard
kbd1 at kbdmux0
module_register_init: MOD_LOAD (vesa, 0xffffffff80e6b860, 0) error 19
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
padlock0: No ACE support.
acpi0: <SUPERM SMCI--MB> on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
cpu4: <ACPI CPU> on acpi0
cpu5: <ACPI CPU> on acpi0
cpu6: <ACPI CPU> on acpi0
cpu7: <ACPI CPU> on acpi0
cpu8: <ACPI CPU> on acpi0
cpu9: <ACPI CPU> on acpi0
cpu10: <ACPI CPU> on acpi0
cpu11: <ACPI CPU> on acpi0
cpu12: <ACPI CPU> on acpi0
cpu13: <ACPI CPU> on acpi0
cpu14: <ACPI CPU> on acpi0
cpu15: <ACPI CPU> on acpi0
cpu16: <ACPI CPU> on acpi0
cpu17: <ACPI CPU> on acpi0
cpu18: <ACPI CPU> on acpi0
cpu19: <ACPI CPU> on acpi0
cpu20: <ACPI CPU> on acpi0
cpu21: <ACPI CPU> on acpi0
cpu22: <ACPI CPU> on acpi0
cpu23: <ACPI CPU> on acpi0
cpu24: <ACPI CPU> on acpi0
cpu25: <ACPI CPU> on acpi0
cpu26: <ACPI CPU> on acpi0
cpu27: <ACPI CPU> on acpi0
cpu28: <ACPI CPU> on acpi0
cpu29: <ACPI CPU> on acpi0
cpu30: <ACPI CPU> on acpi0
cpu31: <ACPI CPU> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x71,0x74-0x77 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 350
Event timer "HPET1" frequency 14318180 Hz quality 340
Event timer "HPET2" frequency 14318180 Hz quality 340
Event timer "HPET3" frequency 14318180 Hz quality 340
Event timer "HPET4" frequency 14318180 Hz quality 340
Event timer "HPET5" frequency 14318180 Hz quality 340
Event timer "HPET6" frequency 14318180 Hz quality 340
Event timer "HPET7" frequency 14318180 Hz quality 340
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
pcib0: <ACPI Host-PCI bridge> on acpi0
pci255: <ACPI PCI bus> on pcib0
pcib1: <ACPI Host-PCI bridge> on acpi0
pci127: <ACPI PCI bus> on pcib1
pcib2: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> irq 26 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib3
ix0: <Intel(R) PRO/10GbE PCI-Express Network Driver, Version - 3.1.13-k> port 0x6020-0x603f mem 0xc7c00000-0xc7dfffff,0xc7e04000-0xc7e07fff irq 26 at device 0.0 on pci1
ix0: Using MSIX interrupts with 9 vectors
ix0: Invalid advertised speed; valid modes are 0x1 through 0x7
ix0: Ethernet address: 0c:c4:7a:a3:24:1e
ix0: PCI Express Bus: Speed 5.0GT/s Width x8
ix1: <Intel(R) PRO/10GbE PCI-Express Network Driver, Version - 3.1.13-k> port 0x6000-0x601f mem 0xc7a00000-0xc7bfffff,0xc7e00000-0xc7e03fff irq 28 at device 0.1 on pci1
ix1: Using MSIX interrupts with 9 vectors
ix1: Invalid advertised speed; valid modes are 0x1 through 0x7
ix1: Ethernet address: 0c:c4:7a:a3:24:1f
ix1: PCI Express Bus: Speed 5.0GT/s Width x8
pcib4: <ACPI PCI-PCI bridge> irq 32 at device 2.0 on pci0
pci2: <ACPI PCI bus> on pcib4
nvme0: <DC P3500 SSD [2.5" SFF]> mem 0xc7610000-0xc7613fff irq 32 at device 0.0 on pci2
pcib5: <ACPI PCI-PCI bridge> irq 32 at device 2.1 on pci0
pci3: <ACPI PCI bus> on pcib5
nvme1: <DC P3500 SSD [2.5" SFF]> mem 0xc7510000-0xc7513fff irq 33 at device 0.0 on pci3
pcib6: <ACPI PCI-PCI bridge> irq 32 at device 2.2 on pci0
pci4: <ACPI PCI bus> on pcib6
pcib7: <ACPI PCI-PCI bridge> irq 40 at device 3.0 on pci0
pci5: <ACPI PCI bus> on pcib7
nvme2: <DC P3500 SSD [2.5" SFF]> mem 0xc7410000-0xc7413fff irq 40 at device 0.0 on pci5
pcib8: <ACPI PCI-PCI bridge> irq 40 at device 3.1 on pci0
pci6: <ACPI PCI bus> on pcib8
nvme3: <DC P3500 SSD [2.5" SFF]> mem 0xc7310000-0xc7313fff irq 41 at device 0.0 on pci6
pcib9: <ACPI PCI-PCI bridge> irq 40 at device 3.2 on pci0
pci7: <ACPI PCI bus> on pcib9
nvme4: <DC P3500 SSD [2.5" SFF]> mem 0xc7210000-0xc7213fff irq 42 at device 0.0 on pci7
pcib10: <ACPI PCI-PCI bridge> irq 40 at device 3.3 on pci0
pci8: <ACPI PCI bus> on pcib10
nvme5: <DC P3500 SSD [2.5" SFF]> mem 0xc7110000-0xc7113fff irq 43 at device 0.0 on pci8
pci0: <unknown> at device 17.0 (no driver attached)
ahci0: <Intel Wellsburg AHCI SATA controller> port 0x7110-0x7117,0x7100-0x7103,0x70f0-0x70f7,0x70e0-0x70e3,0x7020-0x703f mem 0xc7738000-0xc77387ff irq 16 at device 17.4 on pci0
ahci0: AHCI v1.30 with 4 6Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
xhci0: <Intel Wellsburg USB 3.0 controller> mem 0xc7700000-0xc770ffff irq 19 at device 20.0 on pci0
xhci0: 32 bytes context size, 64-bit DMA
usbus0 on xhci0
pci0: <simple comms> at device 22.0 (no driver attached)
pci0: <simple comms> at device 22.1 (no driver attached)
ehci0: <Intel Wellsburg USB 2.0 controller> mem 0xc7734000-0xc77343ff irq 18 at device 26.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci0
pcib11: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci9: <ACPI PCI bus> on pcib11
pcib12: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
pci10: <ACPI PCI bus> on pcib12
pcib13: <ACPI PCI-PCI bridge> at device 0.0 on pci10
pci11: <ACPI PCI bus> on pcib13
vgapci0: <VGA-compatible display> port 0x5000-0x507f mem 0xc6000000-0xc6ffffff,0xc7000000-0xc701ffff irq 18 at device 0.0 on pci11
vgapci0: Boot video device
ehci1: <Intel Wellsburg USB 2.0 controller> mem 0xc7733000-0xc77333ff irq 18 at device 29.0 on pci0
usbus2: EHCI version 1.0
usbus2 on ehci1
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci1: <Intel Wellsburg AHCI SATA controller> port 0x7070-0x7077,0x7060-0x7063,0x7050-0x7057,0x7040-0x7043,0x7000-0x701f mem 0xc7732000-0xc77327ff irq 16 at device 31.2 on pci0
ahci1: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
ahcich4: <AHCI channel> at channel 0 on ahci1
ahcich5: <AHCI channel> at channel 1 on ahci1
ahcich6: <AHCI channel> at channel 2 on ahci1
ahcich7: <AHCI channel> at channel 3 on ahci1
ahcich8: <AHCI channel> at channel 4 on ahci1
ahcich9: <AHCI channel> at channel 5 on ahci1
pcib14: <ACPI Host-PCI bridge> on acpi0
pci128: <ACPI PCI bus> on pcib14
pcib15: <ACPI PCI-PCI bridge> at device 0.0 on pci128
pci129: <ACPI PCI bus> on pcib15
pcib16: <ACPI PCI-PCI bridge> irq 50 at device 1.0 on pci128
pci130: <ACPI PCI bus> on pcib16
ix2: <Intel(R) PRO/10GbE PCI-Express Network Driver, Version - 3.1.13-k> port 0xf020-0xf03f mem 0xfb880000-0xfb8fffff,0xfb904000-0xfb907fff irq 50 at device 0.0 on pci130
ix2: Using MSIX interrupts with 9 vectors
ix2: Advertised speed can only be set on copper or multispeed fiber media types.
ix2: Ethernet address: 0c:c4:7a:bd:70:26
ix2: PCI Express Bus: Speed 5.0GT/s Width x8
ix3: <Intel(R) PRO/10GbE PCI-Express Network Driver, Version - 3.1.13-k> port 0xf000-0xf01f mem 0xfb800000-0xfb87ffff,0xfb900000-0xfb903fff irq 52 at device 0.1 on pci130
ix3: Using MSIX interrupts with 9 vectors
ix3: Advertised speed can only be set on copper or multispeed fiber media types.
ix3: Ethernet address: 0c:c4:7a:bd:70:27
ix3: PCI Express Bus: Speed 5.0GT/s Width x8
pcib17: <ACPI PCI-PCI bridge> irq 56 at device 2.0 on pci128
pci131: <ACPI PCI bus> on pcib17
nvme6: <DC P3500 SSD [2.5" SFF]> mem 0xfbd10000-0xfbd13fff irq 56 at device 0.0 on pci131
pcib18: <ACPI PCI-PCI bridge> irq 56 at device 2.1 on pci128
pci132: <ACPI PCI bus> on pcib18
nvme7: <DC P3500 SSD [2.5" SFF]> mem 0xfbc10000-0xfbc13fff irq 57 at device 0.0 on pci132
pcib19: <ACPI PCI-PCI bridge> irq 56 at device 2.2 on pci128
pci133: <ACPI PCI bus> on pcib19
nvme8: <DC P3500 SSD [2.5" SFF]> mem 0xfbb10000-0xfbb13fff irq 58 at device 0.0 on pci133
pcib20: <ACPI PCI-PCI bridge> irq 56 at device 2.3 on pci128
pci134: <ACPI PCI bus> on pcib20
nvme9: <DC P3500 SSD [2.5" SFF]> mem 0xfba10000-0xfba13fff irq 59 at device 0.0 on pci134
pcib21: <ACPI PCI-PCI bridge> irq 64 at device 3.0 on pci128
pci135: <ACPI PCI bus> on pcib21
pcib22: <ACPI PCI-PCI bridge> irq 64 at device 3.2 on pci128
pci136: <ACPI PCI bus> on pcib22
acpi_button0: <Power Button> on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
ichwd0: <Intel Wellsburg watchdog timer> on isa0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff,0xc9000-0xc9fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: CGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
coretemp4: <CPU On-Die Thermal Sensors> on cpu4
est4: <Enhanced SpeedStep Frequency Control> on cpu4
coretemp5: <CPU On-Die Thermal Sensors> on cpu5
est5: <Enhanced SpeedStep Frequency Control> on cpu5
coretemp6: <CPU On-Die Thermal Sensors> on cpu6
est6: <Enhanced SpeedStep Frequency Control> on cpu6
coretemp7: <CPU On-Die Thermal Sensors> on cpu7
est7: <Enhanced SpeedStep Frequency Control> on cpu7
coretemp8: <CPU On-Die Thermal Sensors> on cpu8
est8: <Enhanced SpeedStep Frequency Control> on cpu8
coretemp9: <CPU On-Die Thermal Sensors> on cpu9
est9: <Enhanced SpeedStep Frequency Control> on cpu9
coretemp10: <CPU On-Die Thermal Sensors> on cpu10
est10: <Enhanced SpeedStep Frequency Control> on cpu10
coretemp11: <CPU On-Die Thermal Sensors> on cpu11
est11: <Enhanced SpeedStep Frequency Control> on cpu11
coretemp12: <CPU On-Die Thermal Sensors> on cpu12
est12: <Enhanced SpeedStep Frequency Control> on cpu12
coretemp13: <CPU On-Die Thermal Sensors> on cpu13
est13: <Enhanced SpeedStep Frequency Control> on cpu13
coretemp14: <CPU On-Die Thermal Sensors> on cpu14
est14: <Enhanced SpeedStep Frequency Control> on cpu14
coretemp15: <CPU On-Die Thermal Sensors> on cpu15
est15: <Enhanced SpeedStep Frequency Control> on cpu15
coretemp16: <CPU On-Die Thermal Sensors> on cpu16
est16: <Enhanced SpeedStep Frequency Control> on cpu16
coretemp17: <CPU On-Die Thermal Sensors> on cpu17
est17: <Enhanced SpeedStep Frequency Control> on cpu17
coretemp18: <CPU On-Die Thermal Sensors> on cpu18
est18: <Enhanced SpeedStep Frequency Control> on cpu18
coretemp19: <CPU On-Die Thermal Sensors> on cpu19
est19: <Enhanced SpeedStep Frequency Control> on cpu19
coretemp20: <CPU On-Die Thermal Sensors> on cpu20
est20: <Enhanced SpeedStep Frequency Control> on cpu20
coretemp21: <CPU On-Die Thermal Sensors> on cpu21
est21: <Enhanced SpeedStep Frequency Control> on cpu21
coretemp22: <CPU On-Die Thermal Sensors> on cpu22
est22: <Enhanced SpeedStep Frequency Control> on cpu22
coretemp23: <CPU On-Die Thermal Sensors> on cpu23
est23: <Enhanced SpeedStep Frequency Control> on cpu23
coretemp24: <CPU On-Die Thermal Sensors> on cpu24
est24: <Enhanced SpeedStep Frequency Control> on cpu24
coretemp25: <CPU On-Die Thermal Sensors> on cpu25
est25: <Enhanced SpeedStep Frequency Control> on cpu25
coretemp26: <CPU On-Die Thermal Sensors> on cpu26
est26: <Enhanced SpeedStep Frequency Control> on cpu26
coretemp27: <CPU On-Die Thermal Sensors> on cpu27
est27: <Enhanced SpeedStep Frequency Control> on cpu27
coretemp28: <CPU On-Die Thermal Sensors> on cpu28
est28: <Enhanced SpeedStep Frequency Control> on cpu28
coretemp29: <CPU On-Die Thermal Sensors> on cpu29
est29: <Enhanced SpeedStep Frequency Control> on cpu29
coretemp30: <CPU On-Die Thermal Sensors> on cpu30
est30: <Enhanced SpeedStep Frequency Control> on cpu30
coretemp31: <CPU On-Die Thermal Sensors> on cpu31
est31: <Enhanced SpeedStep Frequency Control> on cpu31
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
random: unblocking device.
usbus0: 5.0Gbps Super Speed USB v3.0
usbus1: 480Mbps High Speed USB v2.0
usbus2: 480Mbps High Speed USB v2.0
ugen0.1: <0x8086> at usbus0
uhub0: <0x8086 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
ugen2.1: <Intel> at usbus2
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
ugen1.1: <Intel> at usbus1
uhub2: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
nvd0: <INTEL SSDPE2MX020T4> NVMe namespace
nvd0: 1907729MB (3907029168 512 byte sectors)
nvd1: <INTEL SSDPE2MX020T4> NVMe namespace
nvd1: 1907729MB (3907029168 512 byte sectors)
nvd2: <INTEL SSDPE2MX020T4> NVMe namespace
nvd2: 1907729MB (3907029168 512 byte sectors)
nvd3: <INTEL SSDPE2MX020T4> NVMe namespace
nvd3: 1907729MB (3907029168 512 byte sectors)
nvd4: <INTEL SSDPE2MX020T4> NVMe namespace
nvd4: 1907729MB (3907029168 512 byte sectors)
nvd5: <INTEL SSDPE2MX020T4> NVMe namespace
nvd5: 1907729MB (3907029168 512 byte sectors)
nvd6: <INTEL SSDPE2MX020T4> NVMe namespace
nvd6: 1907729MB (3907029168 512 byte sectors)
nvd7: <INTEL SSDPE2MX020T4> NVMe namespace
nvd7: 1907729MB (3907029168 512 byte sectors)
nvd8: <INTEL SSDPE2MX020T4> NVMe namespace
nvd8: 1907729MB (3907029168 512 byte sectors)
nvd9: <INTEL SSDPE2MX020T4> NVMe namespace
nvd9: 1907729MB (3907029168 512 byte sectors)
uhub1: 2 ports with 2 removable, self powered
uhub2: 2 ports with 2 removable, self powered
uhub0: 21 ports with 21 removable, self powered
ugen1.2: <vendor 0x8087> at usbus1
uhub3: <vendor 0x8087 product 0x800a, class 9/0, rev 2.00/0.05, addr 2> on usbus1
ugen2.2: <vendor 0x8087> at usbus2
uhub4: <vendor 0x8087 product 0x8002, class 9/0, rev 2.00/0.05, addr 2> on usbus2
uhub3: 6 ports with 6 removable, self powered
uhub4: 8 ports with 8 removable, self powered
ugen2.3: <vendor 0x0557> at usbus2
uhub5: <vendor 0x0557 product 0x7000, class 9/0, rev 2.00/0.00, addr 3> on usbus2
uhub5: 4 ports with 3 removable, self powered
ugen2.4: <vendor 0x0557> at usbus2
ukbd0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus2
kbd0 at ukbd0
ada0 at ahcich8 bus 0 scbus8 target 0 lun 0
ada0: <SATA SSD S9FM02.1> ACS-3 ATA SATA 3.x device
ada0: Serial Number 7EE20759012400125695
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 61057MB (125045424 512 byte sectors)
ada0: Previously was known as ad20
ada1 at ahcich9 bus 0 scbus9 target 0 lun 0
ada1: <SATA SSD S9FM02.1> ACS-3 ATA SATA 3.x device
ada1: Serial Number 7F2F0759012400116980
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 61057MB (125045424 512 byte sectors)
ada1: Previously was known as ad22
SMP: AP CPU #1 Launched!
SMP: AP CPU #20 Launched!
SMP: AP CPU #9 Launched!
SMP: AP CPU #25 Launched!
SMP: AP CPU #8 Launched!
SMP: AP CPU #19 Launched!
SMP: AP CPU #17 Launched!
SMP: AP CPU #11 Launched!
SMP: AP CPU #29 Launched!
SMP: AP CPU #12 Launched!
SMP: AP CPU #21 Launched!
SMP: AP CPU #5 Launched!
SMP: AP CPU #27 Launched!
SMP: AP CPU #4 Launched!
SMP: AP CPU #28 Launched!
SMP: AP CPU #10 Launched!
SMP: AP CPU #16 Launched!
SMP: AP CPU #6 Launched!
SMP: AP CPU #24 Launched!
SMP: AP CPU #7 Launched!
SMP: AP CPU #23 Launched!
SMP: AP CPU #30 Launched!
SMP: AP CPU #13 Launched!
SMP: AP CPU #31 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #26 Launched!
SMP: AP CPU #15 Launched!
SMP: AP CPU #14 Launched!
SMP: AP CPU #18 Launched!
SMP: AP CPU #2 Launched!
SMP: AP CPU #22 Launched!
Timecounter "TSC-low" frequency 1200025438 Hz quality 1000
Trying to mount root from zfs:freenas-boot/ROOT/9.10-STABLE-201605240427 []...
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
ipmi0: KCS mode found at io 0xca2 on acpi
ipmi0: IPMI device rev. 1, firmware rev. 3.26, version 2.0
ipmi0: Number of channels 2
ipmi0: Attached watchdog
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI>
ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 4> on usbus2
ums0: 3 buttons and [Z] coordinates ID=0
vboxdrv: fAsync=0 offMin=0x489 offMax=0x8cef
GEOM_ELI: Device nvd0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 128
GEOM_ELI:     Crypto: hardware
GEOM_ELI: Device nvd1p1.eli created.
GEOM_ELI: Device nvd2p1.eli created.
GEOM_ELI: Device nvd3p1.eli created.
GEOM_ELI: Device nvd4p1.eli created.
GEOM_ELI: Device nvd5p1.eli created.
GEOM_ELI: Device nvd6p1.eli created.
GEOM_ELI: Device nvd7p1.eli created.
GEOM_ELI: Device nvd8p1.eli created.
GEOM_ELI: Device nvd9p1.eli created.
[root@freenas] ~#
