Hi
Just build my own NAS with TrueNas 12.0. But I'm having severe stability issues, I'm hoping some can help me diagnose.
My brand new setup:
CPU: AMD Ryzen 5 3400G
RAM: Samsung DDR4 PC2666 16GB
Motherboard: Asrock X570M PRO4
Install disk: 1x Kingston Data Center DC1000B M.2
Cache disk: 1x SSD M.2 1TB Samsung 970 PRO M.2
Data disk: 2x 8TB WD WD82PURZ Purple Surveillance
During the night I had 7 unscheduled reboots of the system. Its headless and also nothing comes on the screen when I plug on in, so I cannot see if there is an error in the console. This morning I could not reach the web interface. Had to force shutdown the system and boot again.
Besides the stability issues I have battles Jails not wanting to be installed - But this is only plex so I guessing this is something else.
I have checked the /data/crash folder, but I'm not sure how to read the data. Is dump from device the device that is having issues and is panic string a generic hardware fault or does it point back to the device in question?
root@truenas[~]# cat /data/crash/info.last
Dump header from device: /dev/ada1p1
Architecture: amd64
Architecture Version: 4
Dump Length: 251392
Blocksize: 512
Compression: none
Dumptime: Sat Nov 14 06:09:01 2020
Hostname: truenas.local
Magic: FreeBSD Text Dump
Version String: FreeBSD 12.2-RC3 7c4ec6ff02c(HEAD) TRUENAS
Panic String: page fault
Dump Parity: 323915
root@truenas[~]# cat /data/crash/info.1
Architecture: amd64
Dump Length: 737792
Blocksize: 512
Compression: none
Dumptime: Sat Nov 14 06:07:07 2020
Panic String: general protection fault
Dump Parity: 3743347290
Bounds: 1
root@truenas[~]# cat /data/crash/info.4
Architecture: amd64
Dump Length: 781824
Blocksize: 512
Compression: none
Dumptime: Sat Nov 14 05:43:12 2020
Panic String: double fault
Dump Parity: 2121761597
Bounds: 4
I have not done any form of burn in of CPU or memory - But if Panic string is generic, I'm guessing I need to do a memory test.
Any advice on where I should look or how to read the data at hand or any where else to look for the issue ?
Thanks
Michael
My brand new setup:
Architecture: amd64
Dump Length: 251392
Blocksize: 512
Compression: none
Dump Parity: 323915
Architecture: amd64
Dump Length: 737792
Blocksize: 512
Compression: none
Bounds: 1
Architecture: amd64
Dump Length: 781824
Blocksize: 512
Compression: none
Bounds: 4
Thanks
Michael
