I'm trying to set up Webmin inside a freenas jail. If set up without using SSL then it works fine and I can access Webmin no problem through the browser, however, if I select to install it selecting SSL then it states that the browser can not access webmin as it can not establish a secure connection so I can't get to the panel.
Does anyone have any ideas or come across this problem before?
Thanks
Thanks
