I updated to cobra a few days ago, and since than my SFTP backup tool can not access the NAS any more.
After trying to understand the problem I found in /var/log/auth.log there is the following message:
userauth_pubkey: signature algorithm ssh-rsa not in PubkeyAcceptedAlgorithms [preauth]
Oct 30 20:22:47 lion sshd[2607145]: Connection closed by authenticating user <me> <source-address> port 63945 [preauth]
And strange things here are:
- that the public key is ssh-rsa and that public key is in the related user field, and it does to a certain extend work (see below)
- using another ssh-client (BitVise) using the same key pair, with the same ssh-rsa key defined in the NAS, is simply working
- replacing the pubkey in the nas field with was in openssh-format by the same key in ssh2-format does not solve the problem
- replacing the backup-tool (SyncBackProV10) with the brand new SyncBackProV11 did not solve the problem
Of course I will also contact the SyncBackPro firm, but the NAS behavoir is strange and the error message as well
(the problem message seems not to match the problem !?)
So if someone understands the problem, that would help to overcome or to fix the problem
