{HD}
- Oct 30, 2016
I am having trouble getting my SSH KEYs setup again. I had it working with an old user that is now gone. I am thinking I am setting up the new user the same way. I have posted, what I think to be, all the relevant information.
I am going to post data that will not be used for the final config...but for this post I will be posting private data!
I have a user 'TestSSH' with 'home directory' in "Tank" I believe the users 'auth key' permissions are correct.
I have the users SSH Public Key pasted in the user setup screen
This is the contents of my Private500.ppk file!(I know this is too short and private...Only for testing)
When I try to connect via putty.exe I get a
Putty Event Log:
FreeNAS Console output
ssh -v TestSSH@FreeNas
I have seen many people talk about the .ssh folders permissions but I think they are set correctly. Do you guys see anything that is causing the issue? I can logon via 'password' when I enable that feature in SSH Configure...
-rwx------+ 1 TestSSH TestSSH 138B Nov 8 17:04 authorized_keys
ssh-rsa AAAAB3NzaC1yc2EAAAABJQAAAD8IK8h0tly/ZMGeW26NBHZAjnNVNnkwasiFFp53BqJ7N08WK4Ud5DzL2Tpaf80EXeUdnLWzHyKJ7H5gTQI1uJE= rsa-key-20161108
PuTTY-User-Key-File-2: ssh-rsa Encryption: aes256-cbc Comment: rsa-key-20161108 Public-Lines: 2 AAAAB3NzaC1yc2EAAAABJQAAAD8IK8h0tly/ZMGeW26NBHZAjnNVNnkwasiFFp53 BqJ7N08WK4Ud5DzL2Tpaf80EXeUdnLWzHyKJ7H5gTQI1uJE= Private-Lines: 4 59Hmr+HeB5LOytnE+QHmTumfsE+53A9kKWp0b5V8FDCmcPgH5lkoVL4Ps1AYonfi rsrb2J0KpqvdIlbkEWRMHoiTKOdCRrnlzPeTtR61jjdK+4X7kf/Q2bls3BsqYdQ1 4AHeX9m7WbsnYo3LdbywUZEHs8zyV3WDXEta3Re/2oQTMJoD/vVtm9MvTV+RCyBg H/rhya6UPERkBwjb0z4b3/lJH7hFO9h9RQlZOlYynfE= Private-MAC: 9cb46f8389bf05c0a9c18a401242c0677995b7a9
Disconnected: No supported authentication methods available (server sent: publickey) Server refused our key
Putty Event Log:
2016-11-08 14:24:19 Offered public key 2016-11-08 14:24:19 Server refused our key 2016-11-08 14:24:19 Disconnected: No supported authentication methods available (server sent: publickey)
Nov 8 17:24:28 freenas sshd[56974]: error: Received disconnect from 10.1.10.15 port 50128:14: No supported authentication methods available [preauth
debug1: permanently_set_uid: 0/0 debug1: Fssh_key_load_public: No such file or directory debug1: identity file /root/.ssh/id_rsa type -1 debug1: Fssh_key_load_public: No such file or directory debug1: identity file /root/.ssh/id_rsa-cert type -1 debug1: Fssh_key_load_public: No such file or directory debug1: identity file /root/.ssh/id_dsa type -1 debug1: Fssh_key_load_public: No such file or directory debug1: identity file /root/.ssh/id_dsa-cert type -1 debug1: Fssh_key_load_public: No such file or directory debug1: identity file /root/.ssh/id_ecdsa type -1 debug1: Fssh_key_load_public: No such file or directory debug1: identity file /root/.ssh/id_ecdsa-cert type -1 debug1: Fssh_key_load_public: No such file or directory debug1: identity file /root/.ssh/id_ed25519 type -1 debug1: Fssh_key_load_public: No such file or directory debug1: identity file /root/.ssh/id_ed25519-cert type -1 debug1: Enabling compatibility mode for protocol 2.0 debug1: Local version string SSH-2.0-OpenSSH_7.2 FreeBSD-20160310 debug1: Remote protocol version 2.0, remote software version OpenSSH_7.2 FreeBSD-20160310 debug1: match: OpenSSH_7.2 FreeBSD-20160310 pat OpenSSH* compat 0x04000000 debug1: Authenticating to FreeNAS.local:22 as 'TestSSH' debug1: SSH2_MSG_KEXINIT sent debug1: SSH2_MSG_KEXINIT received debug1: kex: algorithm: curve25519-sha256@libssh.org debug1: kex: host key algorithm: ecdsa-sha2-nistp256 debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none debug1: expecting SSH2_MSG_KEX_ECDH_REPLY debug1: Server host key: 'this data feels private' DNS lookup error: general failure debug1: Host 'FreeNAS.local' is known and matches the ECDSA host key. debug1: Found key in /root/.ssh/known_hosts:1 debug1: rekey after 134217728 blocks debug1: SSH2_MSG_NEWKEYS sent debug1: expecting SSH2_MSG_NEWKEYS debug1: rekey after 134217728 blocks debug1: SSH2_MSG_NEWKEYS received debug1: SSH2_MSG_EXT_INFO received debug1: Fssh_kex_input_ext_info: server-sig-algs=<rsa-sha2-256,rsa-sha2-512> debug1: SSH2_MSG_SERVICE_ACCEPT received debug1: Authentications that can continue: publickey debug1: Next authentication method: publickey debug1: Trying private key: /root/.ssh/id_rsa debug1: Trying private key: /root/.ssh/id_dsa debug1: Trying private key: /root/.ssh/id_ecdsa debug1: Trying private key: /root/.ssh/id_ed25519 debug1: No more authentication methods to try. Permission denied (publickey).
