SSH NFSv4 ACL Passwordless Login
Binary Buddha
Can somebody that has passwordless SSH working post the GETFACL output for their .ssh directory and .ssh/authorized_keys2 file?
I may or may not have screwed the permissions up when I had to rebuild the server. I know that it was working at some point.
My traditional UNIX permissions are as follows:
drw------- 2 binary binary 5 Aug 30 23:37 .ssh/
-rw-r----- 1 binary binary 396 Aug 30 23:37 .ssh/authorized_keys2
Robert Trevellyan
Pony Wrangler
[root@poweredge] ~# getfacl .ssh
# file: .ssh
# owner: root
# group: wheel
            owner@:rwxp--aARWcCos:------:allow
            group@:r-x---a-R-c--s:------:allow
        everyone@:r-x---a-R-c--s:------:allow
[root@poweredge] ~# getfacl .ssh/authorized_keys
# file: .ssh/authorized_keys
# owner: root
# group: wheel
            owner@:rw-p--aARWcCos:------:allow
            group@:r-----a-R-c--s:------:allow
        everyone@:r-----a-R-c--s:------:allow
Binary Buddha
# file: .ssh
# owner: root
# group: wheel
# owner: root
# group: wheel
Nope... That didn't work... Now I can't access .ssh....
Can you get me getfacl -d .ssh?
Old NFSv4 ACLs
# file: .ssh/
# owner: binary
# group: binary
owner@:rw-p--aARWcCos:-------:allow
group@:------a-R-c--s:-------:allow
everyone@:------a-R-c--s:-------:allow​
# file: .ssh/authorized_keys2
# owner: binary
# group: binary
group@:r-----a-R-c--s:-------:allow
New NFSv4 ACLs
# file: .ssh/
# owner: binary
# group: binary
# owner: binary
# group: binary
Robert Trevellyan
Pony Wrangler
[root@poweredge] ~# getfacl -d .ssh
getfacl: .ssh: there are no default entries in NFSv4 ACLs
Robert Trevellyan
Pony Wrangler
Why do you have an authorized_keys2 file?
[root@poweredge] ~# ls -al .ssh/
total 10
drwxr-xr-x  2 root  wheel     6 Mar 12 18:03 ./
drwxr-xr-x  3 root  wheel    19 Aug 14 13:56 ../
-rw-r--r--  1 root  wheel   762 Feb 19  2016 authorized_keys
-rw-------  1 root  wheel  1679 Mar 12 16:31 id_rsa
-rw-r--r--  1 root  wheel   402 Mar 12 16:31 id_rsa.pub
-rw-r--r--  1 root  wheel  1913 Jul  4 14:05 known_hosts
Binary Buddha
total 10
authorized_keys2 is for Protocol 2 of SSH. It works for Freenas.
Binary Buddha
**Scratches Head*** Hmmm... That's what I get too
So, starting from scratch again and rm -rf ~/.ssh and readding the public key through the Freenas Webgui for my account to satisfy the "why aren't you doing it from gui" and those that don't quite know about SSH Protocol 2. After that, shutdown the SSH service via webgui and adding in
LogLevel DEBUG3
in the "Extra Options" section of the service. Because apparently, Freenas overwrites anything you put in /etc/ssh/sshd_config via command line. As per /etc/syslog.conf, the output would be sent to /var/log/debug.log. "Normally" it would be sent to /var/log/auth.log, /var/log/messages, or /var/log/secure. After attempting to login via SSH key I get the output of the attached file. In that bunch of yada yada yada and blah blah following lines of significance as follows:
Sep 2 02:24:53 abyss sshd[12376]: debug3: mm_answer_keyallowed: key 0x8040165c0 is not allowed
Sep 2 02:24:53 abyss sshd[12376]: debug3: mm_request_send entering: type 23
Sep 2 02:24:53 abyss sshd[12376]: debug1: trying public key file /mnt/MAIN/HOME/binary/.ssh/authorized_keys
Sep 2 02:24:53 abyss sshd[12376]: debug1: fd 4 clearing O_NONBLOCK
Sep 2 02:24:53 abyss sshd[12376]: debug1: trying public key file /mnt/MAIN/HOME/binary/.ssh/authorized_keys2
Sep 2 02:24:53 abyss sshd[12376]: debug1: Could not open authorized keys '/mnt/MAIN/HOME/binary/.ssh/authorized_keys2': No such file or directory
Sep 2 02:24:53 abyss sshd[12376]: debug2: userauth_pubkey: authenticated 0 pkalg ssh-rsa [preauth]
Sep 2 02:24:53 abyss sshd[12376]: debug3: userauth_finish: failure partial=0 next methods="publickey,password" [preauth]
Possibility of SSHD not reading it due to permissions. Attempted to chmod -R 600 ~/.ssh and I get "chmod: .ssh/authorized_keys: Operation not permitted". Which I believe is NFSv4 ACLs being a boinker. However, if I modify the NFSv4 ACLs to what Mr. Trevellyan has my user account can no longer access to the .ssh directory.
... WTF Over...
  • debug.txt
SweetAndLow
Sweet'NASty
You need to have UNIX permissions on the dataset that holds your user home directories. You currently have it set to windows permissions. Delete the dataset and start over.
Binary Buddha
Uh... Yeah, no.... I can't delete the data and I don't have enough room to copy it somewhere.
Binary Buddha
Yep that didn't work. Created a new dataset and user homing too that dataset and it didn't work.
