Some ports are blocked?
aihysp
Hello
i have installed 3 jails , Homeasstinet , Node-red, mosquitto
Node-red can see mosqitto, i guess becuse thay are on the jail network??
but all devices in the network cannot connect to that mosqito server...
also node red is not able to connect to HA , with the token
so from what i can see the jails have some kind of block from my network ?
thanks!
Are they NAT or VNET jails?
What ports are those services trying to listen on? (80? 443?)
aihysp
it is vnet i think i dont have NAT cheked
and the ports are 1883 for mosquitto jail for exmpale
and devices outside of the jail network cannot connect
And if you check the dns in the jail or pings, can you get out from it? Do you see a value for iocage get defaultrouter <jailname> ?
aihysp
all pings are going in and back no issues also i am able to accses web gui of the jails
but some services are not working as excpted mainly MQTT Port 1883
also on all my jails iocage get defaultrouter <jailname> will give me my router adress
o have a pfsense router ... maybe i can find some clues there ?
From a website that doesn't have it's certificate in order (so I won't post you the link to it)...
Some Website said:
If you are trying to get a service running as an unprivileged user to bind to port 80 in a FreeNAS iocage jail you will need to do the following:
Set securelevel of the jail in Jail Properties to -1
Add the following two lines to /etc/sysctl.conf inside the jail:
net.inet.ip.portrange.reservedlow=0
net.inet.ip.portrange.reservedhigh=0
I have no idea if this is the problem (I'm working on the theory that the current limit is ports below 2000 aren't allowed for non-root... and that your jail process isn't root), but it should be easy to put back if it doesn't solve the issue.
aihysp
no did not do the trick even after jail reboot
it kind of made it worse now even other devices on jail net cant see it
