currently I do the following in order to backup and protect my most important data the best possible way:
1. Snapshots every day lasting for 7 days; every week lasting for 4 weeks; once a month lasting forever (100years)
2. I use replication tasks from my main Pool to a dedicated Backup Pool in the same FreeNAS device. This backup pool consists of 2 mirrored HDDs.
3. I use cloud sync via SFTP to a cloud provider with files being encrypted. The profile is COPY, meaning data will only be copied to this cloud but not being deleted.
I'd like to exchange number 3, the cloud provider with another off-site backup solution. First, because it's costly and second I don't want to have my data, even tough it's encrypted, to be lying around on cloud servers of any provider.
I have an off-site location where I can establish a VPN tunnel to and I am thinking about setting up a cheap 1-bay NAS (e.g. Synology DS119J) over there. I'd go for a 1-bay because possible downtime due to failure is not a issue for me.
Is the Synology a good device for this purpose or are there better options?
In order to back up the data, I currently see two options:
1. use the SFTP cloud sync option in FreeNAS pointing to this NAS
2. use rsync - I read that synology rsync is somehow different to what FreeNAS rsync does - maybe even incompatible
So, does this make sense? Which way of transferring the backup data should I go for? Due to the VPN tunnel the off-site backup device appears to be in the same network and maybe there are even other options I haven't thought about yet.
thx & Best
macx
thx & Best
macx
