Solaris(panic): zfs: allocating allocated segment
isnoguter
I have a big Problem.
I use FreeNAS Version 9.2.1.5 with RAID-Z1 (3 x 2 TB HDD). In the last days I have increase my capacity with new 3 x 4 TB Disks. I exchanged the Disks one by one and I always wait for the resilver process. It worked well for the first time. After a short period of working, FreeNAS does a reboot and now it wont't boot. The Error Message is attached.
Is there a solution for this problem?
Possible solution: The old Disks???
I still have the old Disks. So I take them back into my NAS and tried to import the Volume. Auto Import doesn't work.
The command "zpool import"
[root@FreeNAS ~]# zpool import
   pool: storage
  state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
        devices and try again.
   see: http://illumos.org/msg/ZFS-8000-3C
        storage                                         UNAVAIL  insufficient re
plicas
          raidz1-0                                      UNAVAIL  insufficient re
plicas
            3495210096767858123                         UNAVAIL  cannot open
            17618189468404861795                        UNAVAIL  cannot open
            gptid/3353763b-9115-11e1-a340-50e549d89962  ONLINE
All the old Disks are Online, but FreeNAS is looking for the wrong gptid.
How can I import my RAID-Z1 with the old Disks?
I really need your help!
D
dlavigne
Guest
Post your hardware specs, the output of zpool history, and the output of zpool status.
isnoguter
Hardware:
Board: Gigabyte GA-H61M-D2H-USB3 F2
CPU: Intel Core i3-2100T
RAM: 8GB
HDD (Alt): 3x WD Green 2TB
HDD (Neu): 3x WD Green 4 TB
zpool status:
[root@FreeNAS ~]# zpool status
  pool: storage
state: ONLINE
        corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 5h31m with 0 errors on Sat Dec 13 20:40:33 2014
        storage                                         ONLINE       0     0     0
          raidz1-0                                      ONLINE       0     0     5
            gptid/c4690ac4-7fce-11e4-9ce1-50e549d89962  ONLINE       0     0     0
            gptid/c9969fae-8095-11e4-a279-50e549d89962  ONLINE       0     0     0
            gptid/220dacfb-8161-11e4-979b-50e549d89962  ONLINE       0     0     0
errors: 1 data errors, use '-v' for a list
zpool history:
 2014-12-13.21:11:48 zpool export -f storage
2014-12-13.21:12:22 zpool import -R /mnt storage
2014-12-13.21:50:48 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 11436243033751789037
2014-12-13.21:50:48 zpool set cachefile=/data/zfs/zpool.cache storage
2014-12-13.21:53:34 zpool online -e storage gptid/220dacfb-8161-11e4-979b-50e549d89962
After replacing the Disks, I read about Enabling ZFS Pool Expansion. Autoexpansion was already on, but I don't have more storage capacity. After a reboot everything looks good, the storage capacity was ok now. Some minutes later, I had no connection to FreeNAS and I get the Error Message (attached Image - Post 1).
In the meantime, I looked at this thread. I could not import my pool (error message attached), but I got another idea.
1. start NAS without HDD
2. detach ZFS Volume
3. Read-only import the pool by Shell in the Web-Administration
If I import the pool with the command zpool import -R /mnt storage, FreeNAS does a reboot and I get the Error Message (attached Image - Post 1).
The shares still work and I create a current backup. The best way is probably to destroy the pool and recreate it.
